how much can i spray with this setup?
Old Nov 4, 2003 | 10:08 AM
SlowAssTA's Avatar
Question how much can i spray with this setup?
i got a stock bore block, stock crank, trw forged pistons, Prowler h-beam rods, cc 224/230 cam, ported heads, gasket matched intake...
i was thiking 300, but realisticly that may be pushing it... i dont know much about N20, so any ideas....
Old Nov 4, 2003 | 04:55 PM
12Second3rdgen's Avatar
I would want a forged crank with the kind of numbers you would be putting out.
On a side note, your intake may not even flow enough to support that much horsepower, so who knows. I would imagine anything over a 200 shot on a stock intake and you would run into the law of diminishing returns.3
Old Nov 5, 2003 | 06:20 AM
SlowAssTA's Avatar
ahhh... thanks for the info...
Old Nov 5, 2003 | 04:39 PM
Rival's Avatar
Maybe not a 300 shot but i would hit a 250. Tune it on the dyno and than you will know how far you can go and still be safe. Your drivetrain/trans is going to need beefing up with all the extra hp. I would look into a progressive controller or a two stage setup. Those two things would make the juice more forgiving on the motor.
Jeff1904
Jun 5, 2016 05:00 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
damnyankee36
Sep 9, 2015 07:06 PM
