Diy Lt1 Wet Kit
Old Oct 29, 2003 | 01:52 AM
limige's Avatar
Diy Lt1 Wet Kit
ok i bought a cc224/236 cam with the idea of supercharging but i won't have the money for the kit for a few years yet. so, this winter i am going through the trans and the rear and putting the cam in....
i'm debating about pistons, i want to put some forged pistons in but since i'm thinking about running nitrous until i can afford the supercharger i'm thinking about going with a higher comp ratio and changing them when the supercharger goes in.
so assuming i drop forged pistons in, i'll have the 224/236 cam with the roller rockers, new springs retainers and pushrods.
how much can i spray it and what type of compression ratio should i go with. i'm replacing the fuel pump since it's crapping out on me, i want to run a wet system borrow my freinds bottle and plumb up a few wet nozzles before the tb.
how much will i be able to run without running into fuel issues running off one pump and stock lines?
thanks,
mike
Old Oct 29, 2003 | 08:28 AM
RacinLT1's Avatar
i was running a 175 hit with stock lines/regulator/injectors and a walbro 255 in tank. ran a 150 shot for about 2 years and the 175 for the last 5 months.
As far as compression,stock or 11:1 is fine,some guys go as high as 12:1,but tuning will be crucial to prevent detonation.
Old Oct 29, 2003 | 10:23 AM
limige's Avatar
i guess the real question is what will be the first problem, not enough fuel or trashed rods/crank. and were is the line. i'm thinking about a double shot, start small and kick in another at higher rpms.
Old Nov 1, 2003 | 11:30 AM
rpm4lalo's Avatar
Get a 255lph in tank fuel pump.
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
