The problem is in the plugs ?
Old Oct 27, 2003 | 06:19 PM
SmokinZtires94's Avatar
Exclamation The problem is in the plugs ?
I had a slight high rpm misfire when sprayin. Everything is fine, bottle psi fuel psi, ect. I found the plugs to b gapped at .055 instead of.032 !!!! Would this cause the misfire alone or do you think the fuel injectors are bad too ? . im only squezzin a 75 shot at the moment . Im just makin sure that plugs gapped that high will create a misfire ? ....... at least i found a potential problem. what do you guys think ?
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
grabbem88
Mar 18, 2015 01:25 PM
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
