Wet NOS with EFI - A couple of Questions
Old Oct 27, 2003 | 08:31 AM
adivanman's Avatar
Question Wet NOS with EFI - A couple of Questions
I am looking at putting together a wet nitrous system for my EFI 502. The configuration of the manifold and throttle body is very similar to a LT1 except it uses an Alpha-N (like the ram jet crate engines) with no MAF, no SD, and no O2. The injectors are 36 pounds and fuel pressure is regulated at 42 pounds. I am looking for 200 HP.
A couple of questions for the EFI nitrous gurus....
1. My throttle body is a dual blade - should I use one or two fogger nozzles?
2. Can I inject right behing the TB or do I have to go through it?
3. What do you regulate the fuel pressure to for the fogger nozzles?
4. Does anyone have the HP and jetting per nozzle?
5. If I do use 2 nozzles, is it fair to double expected HP or are there losses to take into account like with dual carburetors.
I appologize for the simple questions. My history with nitrous has been carbureted plates and foggers. This engine and my MTI 396 LT1 are next in line for the bottle and I am trying to get a handle on the options.
Thanks
Adivanman
Old Oct 27, 2003 | 09:15 PM
rskrause's Avatar
Re: Wet NOS with EFI - A couple of Questions
Either will probalby work. I am using a twin nozzle setup.
Best injected in front of (upstream) of the TB to get more even distribution.
A wet system is designed to run at stock FP. If you want to make it richer or leaner you change fuel jets..
Any kit will have a chart. This is a nice on line calculator http://www.robietherobot.com/NitrousJetCalculator.htm as it include the key variables of nozzle size and fuel and nitrous pressure.
Yep, twice as much nitrous = twice as much hp.
Rich Krause
Old Oct 28, 2003 | 07:30 AM
adivanman's Avatar
Thank you Rich.
Old Oct 28, 2003 | 08:10 AM
rskrause's Avatar
Originally posted by adivanman
Thank you Rich.
You are most welcome! But I meant to point you to http://www.cosmik.org/calculators.htm which is a better jet calculator. It tells you the correct fuel jet to use with a given combo of nitrous jet, and fuel and nitrous pressures.
Rich Krause
Old Oct 28, 2003 | 09:19 AM
adivanman's Avatar
Rich,
Is there are ideal distance in front of the throttle blades with a wet system? When I spoke to NOS about a dry system, two different techs told me everything from 6" max to 12" max. I would assume that a wet system would prefer a straight shot.
Also, does anybody have any experience with throttle position based WOT switches vs. conventional micro switches? I have hear that the TP switches exist but have never encountered anyone using one.
Thanks again,
Adivanman
Old Oct 28, 2003 | 09:34 AM
SpeedtechInc's Avatar
The distance that NX gives for nozzle placement is 2-6" before the throttle body. I have sold quite a few of the TPS switches and I haven't heard anything but good things about them. If you would like a price on a NX nitrous system let me know and I will be happy to get you price. I am currently overstocked on the EFI Race systems that are adjustable from 100-250hp and I could make you a great deal on one! Thanks
Old Oct 28, 2003 | 10:29 AM
rskrause's Avatar
As Steve said, 2-6" seems reasonable. 2" seems kind of close to me. I am not sure why a TPS switch would be better. No problems mounting it, I guess? No personal experience with them though.
Rich Krause
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
