Idle Screw...
Old Oct 27, 2003 | 01:50 AM
Kuruption562's Avatar
Idle Screw...
What happens if you mess without idle screw on the throttle body without disconnecting or doing it the proper way? Cuz i was messin with it a while back and i noticed that after that my car started trippin, holla.
Old Oct 27, 2003 | 01:53 AM
Irocvette355's Avatar
Always do it the right way..now the Throttle Position Sensor is getting a wrong reading...I think it sould be 0.52.-0.54 volts.
Old Oct 27, 2003 | 02:04 AM
What to do now?
What are signs of this sensor trippin?
How do i fix this?
Old Oct 27, 2003 | 02:13 AM
The only way to check if the sensor is bad is to put a voltmeter on it. Go get yourself a haynes automotive manual...that has the correct procedure...
i would get mine but its all the way in my garage and its raining like hell
Old Oct 27, 2003 | 03:37 AM
Im not fimiliar with such manual. Any more help?
Old Oct 27, 2003 | 09:20 AM
aklim's Avatar
You, my firend, have just screwed up your IAC setting and TPS setting. Do this
Another method is if you have a scanner. You can turn the idle screw till it reads between 20-30 counts in the IAC counts section. Then reset your TPS to 0.54V
Old Oct 27, 2003 | 12:56 PM
I get everything except where i am supposed to put the paper clip...
...Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins.
what is the ALDL
Old Oct 27, 2003 | 01:41 PM
aklim's Avatar
here
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
