New to TunerCat need some help
Old Oct 23, 2003 | 04:06 PM
Chris 95' Blk T/A's Avatar
OK folks,
I have a 1995 T/A, A4 (Jet Performance tranny), stock bottom end, stock heads, ATI 8# kit, Lucas 42# injectors, MAC Shorty headers, No CAT, Borla CAT back, Racetronix intank fuel pump (high pressure high volume), descreened MAF, MAF located on the pressure side near TB, stock TB.
I purchased a program from a recommended programmer and car runs way way too rich, fouling plugs, huge black cloud under WOT, I am extremely furstrated at this point. I have been through everything at least 3 times, fuel pressure, compression, injector tests (leaks, etc), it simply has to be programming. I purchased TunerCat today and just awaiting the EE file to start working with it myself.
Guys any help you can give me will be fantastic, I am starting from scratch, never used programers before so any links, tips, hints, heck even flames would be appreciated.
Thank you in advance,
Chris
Old Oct 23, 2003 | 05:53 PM
SMOKNZ's Avatar
Chris,
Are you running the stock cam as well? I swapped over to 42# injectors and was having fouling problems as well. I had changed the injector constants to 42# to match the injectors, but I never changed the injector offsets vs. batter voltage table. That was the key and I haven't had problems with it since. I have the file around somewhere. Let me know if you want it. As far as WOT tuning, you will need to go to a dyno. I imagine your % enrichment at WOT is jacked way up, and using the dyno wideband you can dial the air fuel ratio in pretty fast usually after a few runs. There is an excel spredsheet for this very purpose, and when I used it I dialed in the fuel in 2 pulls. It can be found at http://para.noid.org/~lj/ under his tuner section. It is very informative. Any more questions let me know
Bill
Old Oct 24, 2003 | 08:26 AM
Thumbs up Bill (smokinz)
Thank you for your help, yes I would love to see that file, just email it to infosys@chartertn.net
Yes I am running the stock cam. I am going to make some logs of the engine when I drive it around tomorrow, if I can figure out how to do that for sure.
Thanks for your help Bill!
MDZ28
11
Sep 24, 2015 09:15 AM
whitehooptie
Jul 22, 2015 10:25 PM
jdelaprida
Jun 27, 2015 08:30 PM
2QUIK6
11
Dec 11, 2002 09:38 PM
1BadBrd
Aug 6, 2002 07:04 AM
