Help on Cylinder 3 Miss
Old Oct 19, 2003 | 02:17 AM
AggieTA's Avatar
Ok I have a miss on my #3 cylinder. I pulled the wire and arced the spark from a screw driver to the body. My friend checked the plug and said it was firing. I took it all a part and put it back together and the code went away for like 15 minutes then came back. I need help cuz I be stumped
Old Oct 19, 2003 | 02:34 AM
chpmnsws6's Avatar
try switching the coil packs to the other side and see if the other side misses and the old miss is gone
if so you have a bad pack
Old Oct 19, 2003 | 12:19 PM
AggieTA's Avatar
I wouldn't think it would be the coil considering it is still firing fine and you would throw an ses code if the coil just quite working and for a miss on #3
Old Oct 20, 2003 | 01:23 AM
AL SS590 M6's Avatar
Just because a plug fires does not mean that it's firing properly all of the time. Swap the coil with a different cylinder and see if the miss moves to that cylinder.
Missing can also be caused by a bad injector. Try swapping them around and see if the miss follows it.
Also could be a bent pushrod. While you're pulling the coils pull the tappet cover and check the pushrods on number 3.
Old Oct 22, 2003 | 09:54 AM
AggieTA's Avatar
Yea it ended up just being a bad plug on that cylinder
KYWes
Jun 14, 2022 06:52 AM
BMX Dad
Jul 27, 2015 02:39 PM
94Form
Jul 17, 2015 10:56 PM
NewsBot
Jul 8, 2015 06:47 PM
robyyzpapa
Jul 7, 2015 10:05 AM
