What drag wheels fit without modification?
I have a 98 SS...
I like the Prostars, drag lites, etc...
What set up front/rear am I lookign to get that will fit without modification?
i can do gridning of the caliper though if need be...
i have no clue about what i can use on the front that wont throw off ABS...
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
15x8" rim no problems
15x10" rim, you must give it the redneck backspace to fit without modifications, also you should run a 27" tall tire to avoid having to mess with things. go 7.5" back spacing and it wil tuck under nicely with modifications.
g'luck on whatever you do!
I have Centerline Telestars on my Firebird. The front 15x4 fit perfect. They did not need a spacer or grinding. The rear 15x8 stick out of the wheel well. I cant tell how much because the 28x10.5W Mickey Thompson sticks way off the rim and looks very stupid. But they did not require any spacers or grinding.
Bogart makes wheels that are specific to the 4th Gen F-Body. Steve Monte at SJM Manufacturing sells them. We put a set on George Baxter's new version of the 30th SS Convert. Direct bolt-on. In effect, the "spacer" is already welded to the wheel by Bogart. If you weigh the wheel, standard acorn lugnuts and the required studs (shorter than the Welds or other "shank" style lugs require) there is a nice weight savings over the Welds or Centerlines.
SJM Manufacturing
The Welds typically require the 5/16" spacers in the front, grinding the brake caliper fins in the back, and longer studs... typically 3".
SJM Manufacturing
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
