If Magnafluxing doesn't work on Al, how do I check for cracks?
Old Sep 22, 2003 | 11:42 PM
StudyTime's Avatar
Question If Magnafluxing doesn't work on Al, how do I check for cracks?
I'm picking up a car that is supposed to have "cracked heads". It overheated and ran hot for a while. The heads are Al and I'm not sure if it's blown head gaskets and warped heads OR if they really are cracked. How can I check for cracks?
Now, I know the cracks should be on the intake side of the head where the head bolts go through, but will I see them?
I hate to spend $150 for a shop to tell me they're cracked when I could get another set for $200. Who wants to spend time and money on heads to find out they were a mistake? So, how can I avoid the waste?
You can't magnatize an aluminum head so how do you check it for cracks? A dye?
Still learning,
Ben T.
Old Sep 23, 2003 | 04:58 AM
oil pan 4's Avatar
They use some thing like perma glow or some kind of name like that. It is a dye that you paint all over the aluminium part then clean it off and go over it with a black light and it shows the cracks.
Old Sep 23, 2003 | 08:41 AM
Hot Rod Hawk's Avatar
Re: If Magnafluxing doesn't work on Al, how do I check for cracks?
Still learning,
Ben T.
You use a process called "zyglo" on aluminum then you could follow up with a sonic check for surface thickness imperfections.
Old Sep 24, 2003 | 09:37 PM
NOMAD's Avatar
Cool
On my heads, they shaved a little bit from them to make sure they were true, then they vaccum tested them on some kind of fixture. I'm not sure of the exact process, but those heads had gotten darned hot and are perfectly fine.
I'm also not sure that aluminum heads can "crack" I think they will just warp... But, my .02 cents is only worth about.00005 cents on that
-Shannon
Red97LT1
9
Dec 17, 2014 06:13 PM
Ryabut98
Sep 3, 2002 11:45 PM
danielbmx
Aug 27, 2002 11:11 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
