Bottle opener woes...
Old Mar 26, 2002 | 09:40 AM
Coon Doon's Avatar
Post Bottle opener woes...
I installed my NX remote bottle opener last summer and I have never really got it to work. The opener turns, but the problem I have is: when opening and closing the bottle, it sometimes gets stuck. Meaning if I open the bottle for too long, it gets stuck open and the motor doesn't have enough torque to close it. Same thing happens when closing it.
I thought there was a way to adjust the torque on the motor, but I'm unsure how to do it. Anyone have similar problems?
Shawn
Old Jul 12, 2002 | 05:31 PM
bt96ss's Avatar
I had the same problem so I had to tighten up the clutch. It works alot better now but I still have to hit the switch a few time to fully open or close. Has anyone else had this problem or know of a solution.
Old Jul 12, 2002 | 06:40 PM
n2oTransAmLT1's Avatar
What kind of openers do you all have? I have a Zex remote opener and I notice one day that it would not open when I wanted it too. I heard it turning but my nitrous pressure gauge never moved. I didnt think anything of it cause it never happened again.
What are the possibilities of problems? I want to check so it doesnt happen if Im ever in a time of need!
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 13, 2002 | 08:14 AM
bt96ss's Avatar
I have a NX opener. I think the NX and the ZEX look very similar> Hell they mightbe the same piece. The only real problem I see is that your bottle may no open when you want or in my case it doesn't close tight enough sometimes and I never can never seem to get every leak out I fix one and find another has sprung up. Very slow leak no visible nitrous just enough to tick me off.
Old Jul 13, 2002 | 12:18 PM
gb95zconv's Avatar
Ok guys, I fooled around with mine till I was ready to chunk it in the lake next to my house, then I finally figured it out. You need remove the motor and clutch assembly. Then take the clutch unit out and put it on top or the billet peice that goes on the valve and work it with you hand. Tighten as needed to open and close the valve...then let it sit for an hour or so(this is a good time to have a couple of beers cause your gonna need it) and come back and do it again. I will say this...the clutch it pretty tight when you get it work right.Also make sure you dont bind it up when you put the whole unit on the bottle neck(the base plate should be flush with the outter housing).
I still have to hit the open twice to get it open and I have a pressure guage up front that I can see to confirm its open. Darn thing was a real PITA.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
NewsBot
Sep 30, 2015 04:20 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
