Can someone tell me what size the 75 shot jet is?
Old Jul 13, 2002 | 11:12 AM
95Zman's Avatar
Post Can someone tell me what size the 75 shot jet is?
Also do i need to mount the inject the nitrous before the maf or after. Thanks
Old Jul 13, 2002 | 02:09 PM
n2oTransAmLT1's Avatar
Post
mount after the MAF. Do a search for the size jet you need. That info has to be here somewhere.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Jul 17, 2015 02:47 PM
Latronaxe
Jul 17, 2015 11:55 AM
CARiD
Jul 7, 2015 08:19 AM
Slayer
Jul 4, 2015 03:06 PM
