Do any of you have your timing retarded through the computer itself?
Old Jun 21, 2002 | 06:04 PM
ProCharged95's Avatar
Post Do any of you have your timing retarded through the computer itself?
It seems everyone is using just a retard box not actually using LT1 edit or something else to retard the timing. Mine is at 27 degrees through LT1 edit. How much can I spray with a wet kit with 9;1 compression and be safe?
Old Jun 21, 2002 | 10:46 PM
gb95zconv's Avatar
I dont know much about N2O on blower apps so Im not going to begin to give you advice.....I do use Tunercat to pull a couple of degrees of timing in the 3000+ rpm when I plan on running nitrous unless I am running 100 oct. Lately Ive just been leaving the nitrous bin file in the pcm.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
mikey4play
Mar 15, 2015 11:45 AM
ChrisFrez
Feb 1, 2015 08:26 AM
edman
Jan 22, 2015 02:45 PM
ScottZ
Mar 3, 2004 01:34 PM
