Heater problem
Old Aug 29, 2002 | 09:39 AM
JB_96RS's Avatar
Question Heater problem
I get air blowin out of the floor vent and by the windshield...but nothing out of the dash vents. Before when I would turn the selector **** I would hear vacuum changing in my dash and the air flow would change. Now I get no air from my vents. This happened the same time my ac died......any ideas?
Old Aug 29, 2002 | 12:33 PM
NeoPaladin's Avatar
I had a problem like this about a year ago. Turned out to be a vacuum leak in the A/C system. If you take it to a shop, they should be able to locate it for you.
1994 Black Firebird 3.4L
Mods include:"Ghetto Master" K&N FIPK, Crane 8MM Plug Wires and Accel Coil Packs, ASP Underdrive Pulleys, SLP Take-off Shocks and Struts, Edelbrock Performer RPM Catback, Catco Hi-flo Cat, 1 pc. steel DS, built GM 4L60E transmission.
Founder of the Free Aqua M&M's Society
Track Times (only FIPK).
E/T: 17.209
MPH: 77.326
Proudly posted!
Old Sep 2, 2002 | 02:07 AM
fbird95's Avatar
I had the same problem. The best place to start checking is the a/c check valve located on the passenger side of the engine compartment near the firewall. It is a black valve and has three vacumn lines going into it. It is a 4 dollar part. When the valve looses pressure the car returns the air flow to its pre set position of defrost and floor vents. If this is the problem you could swop the valve and save a good chunk of money.
kksi
Feb 17, 2015 10:41 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
