Vette servo
Old Sep 9, 2003 | 11:01 AM
pigsticker's Avatar
Vette servo
I've seen this mentioned in several threads. What is it, where does it go, and where can you pick one up?
Old Sep 9, 2003 | 11:48 AM
82355's Avatar
It goes in your tranny, it replaces the small apply area stock servo with the Corvette piece witch has a much larger apply area. Giving you a firmer first to second shift with less chance of the band slipping. Any tranny shop should be able to get you one, they are kind of a standard rebuild piece.
Martin
Old Sep 9, 2003 | 11:55 AM
87DJP2001's Avatar
If you have to ask what it is and its location, my opinion would be that you don't need it. So do a little more research on the subject. (hint: in the tranny)
Old Sep 9, 2003 | 06:33 PM
mrr23's Avatar
now this is for the super servo. but, same place just a different kind of servo.
http://www.technovelocity.com/chevyh...per_servo.html
Old Sep 12, 2003 | 11:38 AM
Pro Built Automatics's Avatar
Get an ATSG book and see where it goes, or do a little research on this as there is plenty of information on this. As to what the Corvette servo does, it will firm up 2nd gear (apply area larger) & 3rd gear (accumulation, more apply oil directed to 3rd gear).
Mikes 1994 z28
Oct 10, 2015 07:55 AM
lil305gta
Aug 16, 2002 07:20 AM
lil305gta
Aug 12, 2002 07:58 AM
IROCKER
Aug 9, 2002 08:54 AM
lil305gta
Aug 8, 2002 03:08 AM
