engine horsepower?
Old Sep 6, 2003 | 04:15 PM
kandied91z's Avatar
Question engine horsepower?
what is a good calculator to use to figure out a general rule of thumb on what a particular combo should attain?
Old Sep 6, 2003 | 07:00 PM
SSpdDmon's Avatar
I'm a good calculator when it comes to guessing #'s. What kinda mods/tranny are you running?
Old Sep 6, 2003 | 07:38 PM
kandied91z's Avatar
Smile
i sent you a pm..
Old Sep 7, 2003 | 02:08 AM
SSpdDmon's Avatar
kandied91z wrote on 09-06-2003 08:37 PM:
here is one of the setups
gm 383 4 bolt main.
fastburn aluminum heads with 1.5 rockers
tpis zz-409 cam
tpis miniramIII
30lb injectors
700-r4
2800 stall
3.23 rear
Hmm...I didn't think the car was this heavily modified. I thought you were gonna be talking cold air intakes and catbacks. Either way, I'll take a guess just for the hell of it. I'd say that setup would be close to 430~440hp @ the crank...360~370hp @ the wheels. I wouldn't be surprised if I'm off though.
Old Sep 7, 2003 | 04:09 PM
kandied91z's Avatar
forgot the custom 4" cold air intake, custom 1 3/4 LT headers and 4" exhaust.
Old Sep 7, 2003 | 06:59 PM
AutoRoc's Avatar
and compression
Old Sep 7, 2003 | 07:05 PM
AutoRoc's Avatar
total timing
Old Sep 7, 2003 | 07:10 PM
AutoRoc's Avatar
rod length...bushed?
TreySpeed's Avatar
On permanent vacation
head flow charactoristics
Old Sep 7, 2003 | 07:19 PM
AutoRoc's Avatar
355HP
360TQ
At the wheels. Power peak at 5700 maybe? You said somewhere else that the heads were worked also. Only you know how much. There could be 20-60hp in a correctly placed head massage.
Old Sep 7, 2003 | 07:22 PM
AutoRoc's Avatar
Honestly I dont trust any numbers I've seen floating around. GM claimed 270-285 cfm at .500-.700 lifts a while back and now someone said SDPC shows a 230'ish CFM at .500 which is what a Vortec head flows roughly with it's 40cc smaller port...So... Fastburn heads are basically a GM developed ALum head with 210/78cc ports, 2.02/1.60 valves, a fastburn chamber with a better spark plug location, and so called "perfect ports". They really should make good power.
Old Sep 7, 2003 | 08:46 PM
kandied91z's Avatar
the compression is only 9.7.1 right now...the rod length is standard and i'm not sure on the timing right now. regardless i need to find someone who knows a thing or two as tpis really screwed up on some parts unfortunately.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 29, 2015 07:10 PM
CARiD
Jan 27, 2015 06:27 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
