posi?
Old Sep 3, 2003 | 02:39 PM
CLEAR's Avatar
posi?
ok in my 98 m5 i have 3.23 gears. im pretty sure i dont have limited slip because it will only spin one wheel. well i have gotten it to spin both on 2 occasions and that was on very smooth blacktop. is their a code for lsd cuz i wanna find out what i have.
Old Sep 3, 2003 | 02:47 PM
99blackSS's Avatar
G80-limited slip
You probably do have posi. It gives power to the wheel that has more traction, this could be why the other times you only saw one mark. My friend has a peg leg truck and it always does one mark.
Old Sep 3, 2003 | 02:50 PM
CLEAR's Avatar
i just looked. no g80
Old Sep 3, 2003 | 05:32 PM
oil pan 4's Avatar
see for your self,
Go to howstuffworks.com and look up differental and look at the picture and then look up zexal-torsen after that blows your mind then pull off the diff cover of your car and see what you have.
A regular diff and stock limited slip look way different.
sounds like you don't have limited slip to me.
Old Sep 4, 2003 | 06:05 PM
mike996's Avatar
so limetid slip = posi?
And where can i find the code?
Old Sep 4, 2003 | 08:29 PM
99blackSS's Avatar
Limited slip is the same as posi. The RPO numbers are on the inside of the drivers door on the door jam.
vwb11356
Jul 22, 2015 06:51 PM
mrwz28
Jul 8, 2015 09:11 PM
cristian1311
May 1, 2015 08:56 PM
TitoPR221
Jan 29, 2015 08:00 PM
