how much N20 on a stock LT1?
Old Sep 3, 2003 | 12:22 PM
94Zpower's Avatar
I am in the works of buying a N.o.s dry plate kit for my internally stock LT1 with aprox 70k miles on it and was wondering how much I could spray safely? I was thinkg 75hp or max 100hp shot, what do you think?
thanks!
Old Sep 3, 2003 | 01:47 PM
RacinLT1's Avatar
i am spraying 175 to my stock LT1. i have a good fuel pump and a good fuel system.
i wouldnt go over 125 with a dry kit.
Old Sep 3, 2003 | 05:33 PM
94Zpower's Avatar
Thanks for the reply! what are you running interms of fuel system? and should I do any upgrades to mine?my fuel pump is original should I change itor get in line fuel pump to boost pressure? sorry for all the questions but I am a N20 newbie and want to do right once with out blowing any thing up!
and also do you think that running a 100 shot will kill my 4L60?
btw: your T/A looks bad ***!!
Thanks!
Old Sep 3, 2003 | 06:46 PM
Derrick Redd's Avatar
Ditto. I'm running a NX 175 shot also. Upgraded to a 255lph Walbro intank. No fuel issues. I also wouldn't go over a 125 with a dry kit. Look into upgrading your injectors for a dry shot. It's good insurance, as the stock injectors tend to lock up a high fuel pressures. Good luck.
Old Sep 3, 2003 | 07:26 PM
94Zpower's Avatar
Thanks for th tip on the injectors, but do you think that an upgraded fuel pump will be needed for my application?
Old Sep 3, 2003 | 09:10 PM
IMO I wouldn't go over a 100 shot on a stock fuel pump. That's just me. I like the added insurance of a upgraded fuel pump.
Old Sep 3, 2003 | 09:33 PM
jkbadz28's Avatar
I took Derrick's advice sprayed the 175 several times with no problems at all. Also had ton's of runs with the 150 jets in with nothing but sucess. I did have a fuel pump also with colder plugs and a good ignition.
JK
Old Sep 3, 2003 | 09:54 PM
94z'sson's Avatar
my dad and i have sprayed over 250 with a 255lph pump and colder plugs on a stock internal LT1
nothing but solid low 11s and not too many boltons
Old Sep 3, 2003 | 10:02 PM
RacinLT1's Avatar
over 250 is asking for it.
i have a walbro 255lph in tank,and yes i recommend a fuel pump on ANY car pressing 8+ years or older. cheap insurance.
cant help much with dry kits,i refuse to work on or tune them unless the car has a killer engine management and fuel system to match.
thanks for the compliment on the car,i try to keep her looking decent.
Old Sep 3, 2003 | 10:24 PM
ltlhomer's Avatar
As long as you have a FPSS, aren't you okay to run say 75 shot on a heads/cam car. I mean if fuel pump "dies", you'll have no pressure and therefore no nitrous. Works in theory, right? I'm thinking about nitrous for next spring btw.
Edit: I'll be going wet kit btw.
Old Sep 4, 2003 | 07:34 AM
94Zpower's Avatar
I have a MSD 6A and coil as ignition mods and will be getting accel 24# injectors from a friend that dosen't need them for pretty cheap, and now I am gonna look in to fuel pumps now so I can get all the parts I need to do this right b4 I start the install,
the colder plugs I new about allready and will get 2 steps colder, what plugs do you suggest?
thanks
Old Sep 4, 2003 | 08:26 PM
RacinLT1's Avatar
ngk tr6 or autolite 103/104
Old Sep 8, 2003 | 09:58 AM
N2OpwrdTA's Avatar
Sounds like the perfect kit for you would be a Zex kit ...but i guess NOS will work also. Anyhow, the zex kit comes with an inline fuel pump. Is an really cool kit also. Pics of it in my car on my site. I have run it for a long time now on 125shot with no injector lockup...using my stock injectors. Most people just read that "tip" and repeat it as advice. I think you would need a decently modded engine and a 125shot to even have a chance at locking them up. Either way, with small shot dry kit your engine should be fine. Just watch out for detonation...thats what crated my forged 355
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
