Advice on a 355....
Old Jun 12, 2002 | 11:47 AM
91Bird305's Avatar
Question Advice on a 355....
Well atleast I think I did. Tell me what u guys think
'69 4-bolt 010 high nickel block (2-pc rear main, ARP main bolts)
-block was tanked, decked, bored .030"
10/10 cast crank
3/8" bolt Truck rods, ARP bolts
TRW flat top forged pistons, 9.82:1 compression
Moly total seal rings
Clevite77 bearings
Moroso 7 quart oil pan and pickup
Melling standard volume oil pump
Crane Energizer hydraulic cam and lifters
-284 advertised duration
-228* duration @ .050"
-.480" lift with 1.5:1 rockers
-112 LSA
-installed straight up
Cloyes true double roller timing chain
Cast aluminum timing cover
Sportsman II heads, 64cc chambers, 2.02/1.60 stainless valves, springs can handle up to .550" lift
1.5:1 aluminum roller rockers
Comp Cams magnum pushrods
Victor Jr. Intake
750 4160 Holley w/secondary metering block conversion and quick change secondary spring housing
Summit Racing distributor, 50,000 volt coil
Full accessories(water pump, alternator, PS pump, starter, brackets, belts)
Now what should I ask for this engine? He is a friend from where I Live and he told me to make him an offer. Any other questions I should ask him? He said it has 6000 trouble free miles on it and all I need is some headers and a battery and I am ready to go.
1991 Firebird 305
Eric Natzke
"It ain't Stock"
http://members.aol.com/j007golden/91firebird.html
Old Jun 12, 2002 | 09:25 PM
texlurch's Avatar
Judging by that parts list, IF you had a stock shortblock to start with, you would be looking at around $3500 - 4000 to do one similar.. GM crate motors similar are about that price also
Since he is a friend, let your conscience be your guide.. ask him what he wants for it, and deal from there, that way you both end up happy
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old Jun 15, 2002 | 05:02 PM
HeavyChevySS's Avatar
$3500-$4000 sounds about right to me...
Old Jun 15, 2002 | 08:21 PM
joesmith69's Avatar
Cool
Hey Eric,
I was hoping for $2,500 or so. These guys are just boostin my stock. Anyways, just make me a reasonable offer. I hardly expect $3,500+ for this motor.
-Joe
79' Z28 4-spd
http://joesmith59.freeservers.com/
*Boycott Lapeer*
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
