Advice on a 355....
Well atleast I think I did. Tell me what u guys think
'69 4-bolt 010 high nickel block (2-pc rear main, ARP main bolts) -block was tanked, decked, bored .030" 10/10 cast crank 3/8" bolt Truck rods, ARP bolts TRW flat top forged pistons, 9.82:1 compression Moly total seal rings Clevite77 bearings Moroso 7 quart oil pan and pickup Melling standard volume oil pump Crane Energizer hydraulic cam and lifters -284 advertised duration -228* duration @ .050" -.480" lift with 1.5:1 rockers -112 LSA -installed straight up Cloyes true double roller timing chain Cast aluminum timing cover Sportsman II heads, 64cc chambers, 2.02/1.60 stainless valves, springs can handle up to .550" lift 1.5:1 aluminum roller rockers Comp Cams magnum pushrods Victor Jr. Intake 750 4160 Holley w/secondary metering block conversion and quick change secondary spring housing Summit Racing distributor, 50,000 volt coil Full accessories(water pump, alternator, PS pump, starter, brackets, belts) Now what should I ask for this engine? He is a friend from where I Live and he told me to make him an offer. Any other questions I should ask him? He said it has 6000 trouble free miles on it and all I need is some headers and a battery and I am ready to go. ------------------ 1991 Firebird 305 Eric Natzke "It ain't Stock" http://members.aol.com/j007golden/91firebird.html |
Judging by that parts list, IF you had a stock shortblock to start with, you would be looking at around $3500 - 4000 to do one similar.. GM crate motors similar are about that price also
Since he is a friend, let your conscience be your guide.. ask him what he wants for it, and deal from there, that way you both end up happy ------------------ Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR ;) " a little spray never hurt anyone, spank you very much!" or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?" |
$3500-$4000 sounds about right to me...
Hey Eric,
I was hoping for $2,500 or so. These guys are just boostin my stock. http://web.camaross.com/bb/wink.gif Anyways, just make me a reasonable offer. I hardly expect $3,500+ for this motor. ------------------ -Joe 79' Z28 4-spd http://joesmith59.freeservers.com/ *Boycott Lapeer* |
