Flames from under the hood!!!!!
Old Sep 8, 2002 | 09:48 AM
Bowtieboy28's Avatar
Red face Flames from under the hood!!!!!
ok so i just got my 82'Z back after not having it for 2 years (it was at my grandparents house) anyway it was recently tuned up and shipped here the the only problem, and it's kinda a big problem, is that it idles REALLY rough and generally stalls unless i keep a little pressure on the gas. Also when i punch it at lower speeds (anything under about 60-70mph) it makes a sputtering/spitting sound and sometimes i get flames shooting out the hood. I don't have a clue what's wrong with it please help. I don't know if it's any help but it's got a 350 duel plane intake and 4bbl carb.
Old Sep 8, 2002 | 12:08 PM
blueirocz-28's Avatar
timing?? we were timing my brother inlaw's olds cutlass 442 b/c he had timed it wrong last weekend and there were flames (backfire) coming out the carb.
Tyler Parsons
'85 IROC-Z
'94 Camaro 3.4L -160 degree stat, throttlebody bypass
Old Sep 8, 2002 | 01:24 PM
TheGreatJ's Avatar
Exclamation
Definitely sounds like your timing is all shot up...maybe the distributor got moved during the tune-up? Break out the timing light and see what the tab reads. Should be about 6-10 degrees base advance...it's a good place to start if nothing else.
TheGreatJ
1991 Camaro RS "Suzanne"
http://thegreatj.cz28.com
Old Sep 8, 2002 | 08:57 PM
don't forget to pull the vaccum tube off the advance canister on the distributor when you time it. at least thats what i've always been told to do.
Tyler Parsons
'85 IROC-Z
Old Sep 8, 2002 | 10:42 PM
smallwood's Avatar
A flat cam lobe will cause a backfire through the carb as well.
Little red light on the highway; big green light on the speedway, hey,hey, hey!
2002 Formula, GMMG cat back /1983 Z28-sold
Old Sep 9, 2002 | 08:37 AM
1989gta's Avatar
so will having the distributer off by 180 degrees. Though i'm not sure if you can make it drivable if its that far off. I have heard about weirder things.
Old Sep 9, 2002 | 12:45 PM
Chris`s85Z28's Avatar
when you set the timimg take the vacum line off the vacum advance I forgot one time and my car did that same thing
R.I.P Dale Earnhardt 3 Nascar isn`t the same without you
1985 Z28 My pride and joy
LG4 305 5spd T-tops 3:23 posi 2.5" exshust mild street cam Accel wires shorty plugs cap rotor and a H.E.I super coil
5.0L BEWARE
http://Chevy-Camaro-Z28.CZ28.com
Speed limits Whats that???
Kills 1/0
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
