fuse problum!!!!
Old Aug 25, 2003 | 04:04 PM
raider5.0's Avatar
fuse problum!!!!
i am having a problum with the fuse that runs my inter lights, keyless entry, and my radio now the fuse was blown before i put in my after market stereo in, so i replaced it to find that it blow again after that it lasted for about 3 days and now i cant put an fuse in there with out it blowing it instantly any suggestions thanx.
Old Aug 25, 2003 | 07:06 PM
x7x7's Avatar
I will try to help you with your fuse PROBLEM.
Sounds like something is shorting out. If you just recently installed a stereo I would suspect that you knicked a wire in the dash and it's shorting to ground and popping the fuse. Remove the HU and look for a damaged wire. Definately sounds like a short somewhere. Good luck.
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
