the dreaded thud from the rear suspension
Old Aug 16, 2002 | 01:34 AM
puckboy60's Avatar
Post the dreaded thud from the rear suspension
i dont remember which it is..the shocks or struts that make the noise when they go but how big of a job is it to do yourself...i just spent 2900 dollars on my car in the past 2 months so i'm really lookin to do the job myself if possible..any comments or suggestions would be appreciated
Old Aug 16, 2002 | 02:36 PM
Z28ROC's Avatar
When is the problem occuring? If your getting a thump upon acceleration. I'd check the tranny mount first. Very common on these cars.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Aug 16, 2002 | 02:45 PM
puckboy60's Avatar
i mainly get the thud when going over a bump or up the curb on my driveway, so that would lead me to believe it isn't the trans mounts
<font face="Verdana, Arial" size="2">Originally posted by Z28ROC:
</font>
Old Aug 16, 2002 | 03:56 PM
91RS5speed's Avatar
Did u change the lower controls and panhard rod? If so you could have preloaded them when you put them in. This can cause a clunking noise. Another thing it could be is if you chunked a curb or were in a wreck it could have bent some of your suspention. I would look under the car and check things out before u start spending your cash.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 17, 2002 | 01:48 AM
puckboy60's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 91RS5speed:
</font>
nope i haven't done any of that to the car, and the rear has never been wrecked either
Old Aug 18, 2002 | 07:57 AM
87DJP2001's Avatar
Lightbulb
How about checking for a loose rear shock, thats what it sounds like from you description. Also the Tranny Mount is another one to look at while you are under the car.
Old Aug 18, 2002 | 01:09 PM
Gear Breath's Avatar
I had the same problem. Going up driveways or on hard accelleration, drove me nuts. Replaced all the rr bushings. Still did it. Someone told me to replace the trans mount and torque arm bushing, and the clunk disappeared!
For some reason, it sound like it's coming from the back of the car. Try it before you throw away a lot of time and cash. Good luck.
Old Aug 18, 2002 | 01:58 PM
puckboy60's Avatar
how can i tell, from looking at the trans mounts, if they are bad.
Old Aug 18, 2002 | 04:08 PM
86 redbird's Avatar
since it's not a big deal it is probally just easier to change it instead of looking at it. I think they are like 7 bucks and it only requires taking out like 5 bolts. But if you're looking at it, It should look dryrotted and probally be mismatched from the top and bottom part. Like I said probally easier to change it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
94z28jbw
Sep 8, 2002 03:22 PM
guionM
18
Jul 23, 2002 04:24 AM
