Gas tank dilema..................
Old Aug 14, 2002 | 01:45 PM
ZDADDY92's Avatar
Question Gas tank dilema..................
I recently pulled out my gas tank to put in a new fuel pump, but as I was taking it out, I must of put a little to much muscle into it and I bent the filler neck pretty good. Any one have any ideas? What I really want is a tank with a neck that removes like on my buddy's mustang, but I dont know if I could set up this tank like that...Any info is appreciated.
92 Z-28
305TPI-5speed
3.42gears
B&M RIPPER
K&N AIR FILTERS
Hypertech Fan Switch
160 THERMO.
14.7@96MPH(stock run)
Old Aug 14, 2002 | 06:01 PM
IrocSS85's Avatar
I did this to my tank and it makes it soooo much easier to remove. even by myself. I bought a piece of rubber hose off another vehicle that already had a setup like that from my dealership. all you need is a piece of 2.5" diameter fuel compatible hose and two clamps and a hack saw. there is a small diameter pipe inside the neck that also needs to be cut through. when you get done cutting, make sure to clean it out real good cause you dont want those metal chips going into your new fuel pump. I cut mine where it is straight. between the bend and the crimps on the neck. I'll try to remember to get some pics of it tomorrow cause I left it at work (my t.v. cable is broke and it will be there in the mourning)(I work as a mech. at a pont. dealership)
alot of auto parts store's like NAPA sell that hose in bulk, so you may have to buy like 3 feet or so to get it. mine was from a new'ish Jimmy. same diameter neck and its steel.
I have a stock fuel tank for sale if interested. you should be able to bend your back though. email me if anyother questions or would like to buy my tank. its perfect. $45 plus shiping.
chris
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.13.34 @102mph best w/that combo. have trick flow heads and tighter conv. to put in currently.
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Aug 16, 2002 | 02:40 AM
ZDADDY92's Avatar
Exclamation
Sweeeet....thanks for the info, I am going to try that asap. If you could get those pics to me that would be great!
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
