24# Injectors will they be to much
Old Aug 14, 2002 | 01:56 PM
1FastIroc87's Avatar
Post 24# Injectors will they be to much
I have a 87 305 tunedport injection it has headers, bigger runners and a fuel pressure regulator along wiht other stuff. will the 24 pound injectors be good or to much?
Old Aug 14, 2002 | 02:52 PM
86ZZ4's Avatar
it will be the same as you trying to get a drink of water out of a fire hose.It will surprise most people how far you can really go without changing injector size.you are fine where you are,with 24# FP would need to be so low at idle it would have crap for spray pattern.Im running #19 SVO injectors at 50 PSI and it does fine.
86 ZZ4 Z28 traction impaired 13.700@102.7,with a blazing 2.10 60 ft on junk street tires, ,69 AMX mostly stock,12.94@102.3 with sticky tires
[This message has been edited by 86ZZ4 (edited August 14, 2002).]
Old Aug 14, 2002 | 08:01 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Your stock 19lbs injectors with the pressure about 46-48 lbs will be just fine. You only need bigger injectors if you're running a blower or nitrous. And usually with a bigger engine.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Aug 15, 2002 | 01:51 AM
Zepher's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86ZZ4:
Im running #19 SVO injectors at 50 PSI and it does fine.</font>
SVO Injectors are rated differently since Mustangs use a different Fuel Pressure.
Your 19# SVO's are actually running @ 22#'s.
I read this yesterday on one of our local boards.
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
Old Aug 15, 2002 | 08:42 AM
IROC5.7TPI's Avatar
I am agreeing with Zephyr. I also read an article about engine size affecting flow ratings.
Any given injector has many variables to consider.
1) Fuel pressure
2) BSFC (Brake Specific Fuel Consumption)
3) Volumetric Efficiency of the monster.
These three factors all relate to rated injector flow. Thats why we have injectors balanced and flow tested. We then get a printout of the actual flow vs. rpm vs. fuel pressure vs. cid.
But in answer to your ?
You need to stay with stock 19lb.
If you have one sticking or any leaking problems just switch over to stock (dare I say it?) Mustang injectors. Lidio over at Alternative Auto usually has a few sets laying around with less than a few thousand miles on them and will sell them relatively cheap (like garage sale prices!)
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
