cutting out @ 1/4 throttle and low rpm
Old Jul 23, 2002 | 09:03 AM
1989gta's Avatar
Post cutting out @ 1/4 throttle and low rpm
I had tpis burn a chip for me three years ago. and every year i change something and up grade a possible problematic component.
Basically what happens is that when your light on the gas at low rpms it cuts out (2200 and 1/4 throttle). tpis put this on their lap top and @ a certain rpm it shuts off voltage, fuel, spark everything it's like the car just turns off then back on. On full throttle the car goes like a raped ape!
but this drivabilty thing is annoying epecially when driving with girls in the car.
Any help would be great, thanks guys
Old Jul 23, 2002 | 03:13 PM
STAYBG's Avatar
YOU I GOT THE SAME EXACT PROBLEM AND IM GETTING CODES 22,32,AND 33, SO IF YOU FIGURE IT OUT THEN COULD YOU LET ME KNOW?I GOT THE STOCK CHIP WITH ALL MY MODS.I THINK THATS MY PROB BUT WHO KNOWS?
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2 chamber flowmaster cat-back system.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
ALL AROUND SUSPENSION KIT
Old Jul 23, 2002 | 08:59 PM
IrocSS85's Avatar
could be lots of things. you can try unplugging the MAF and see if it goes away. if it does, then you ned a new MAF sensor. it reads how much air the eng. is seeing, so if its wrong, it throws everything off. other then that, maybe dirty fuel inj.s? bad Throttle Position sensor. cant think of anything else. Id put a scan tool on it and see if any of the sensors are wacked out when it happens. good luck ---
chris
Old Jul 23, 2002 | 11:19 PM
Bristol's Avatar
I had a very similar problem when I put in my chip. After 10min of running great the car would try to stall when I was stopped and had brutal if any throttle response when Id take off. Once I got going she screamed. Put the old chip back in and it runs fine. Im getting the chip reburnt. Maybe you could try that too. Just a thought.
Old Jul 23, 2002 | 11:37 PM
Z28ROC's Avatar
Check your TPS. My Iroc was doing the same exact thing. Then I noticed the the TPS adjustment was all the way to one side. I set it in the middle and it completely went away! So I just knocked on wood and didn't bother to check the voltage.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Jul 24, 2002 | 09:30 AM
1989gta's Avatar
Angry
Here's what i've done since the problem started.
-tpis mini ram
-383
-adjusted tps
-swapped out numerous maf sensors
-replaced intake gaskets #'s of times
-adjust timeing and fuel pressure
-new injectors
-multiple chips from tpis
-fuel system (pump lines and regulator)
-coils
-wires
-plugs
-distributor parts
My throttle response is great, just at 2200 rpm and 1/4 throttle it cuts out like it's in over drive @ 20 mph.
I'm going to have a friend burn me a chip if not i'm going to replace the ecm. It's been 3 years now.
It has to be a dead spot somewhere.
Old Jul 25, 2002 | 04:16 PM
1989gta's Avatar
Tried playing with the tps and then moving idle set screw open. That seemed to help. drivability is much better.
I still think i'm going f.a.s.t. next year.
[This message has been edited by 1989gta (edited July 29, 2002).]
Old Jul 29, 2002 | 08:10 AM
1989gta's Avatar
posible fix
Old Jul 29, 2002 | 10:20 AM
STAYBG's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 1989gta:
posible fix</font>
SO WHATS THE PROBLEM?
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
