Starter
Old Jul 25, 2002 | 03:33 PM
babyIroc87's Avatar
Post Starter
my starter needs to be replaced and i'm in a circle. I call the dealerships and they only get a part for the car and when I call Summit racing they need specifics about the part. How do I find out what I need? I need to know how many teeth are on the flywheel and if it is straightaccross or stagard.
Old Jul 25, 2002 | 04:13 PM
1989gta's Avatar
well you can find out how many teeth there are or buy the csi mini starter and that is universal mine will mount like 4 different ways.
Otherwise you need to do some research with your vin # you should be able to find out if it is a 1 or 2 piece rear main then you can find out which fly wheel you have.
Old Jul 25, 2002 | 09:19 PM
angel71rs's Avatar
Eyeball the 2 bolts holding your starter. If they are in line (in a line parallel to the flexplate), you have the small flexplate, 153 teeth. If they are staggered, you have the large flexplate, 168 teeth.
If you need a hi perf unit, get it at Summit. Stock replacement, Autozone has them for about 30 bucks complete with solenoid. Lifetime warranty.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
