fault code 43
Old Aug 13, 2003 | 07:41 PM
bmillington's Avatar
fault code 43
I have probablems with my 305 tpi hasitating when cold and it finaly got bad enough to give me a 43 fault code (Electronic Spark Timing, low voltage). Is the ignintion module the most likely cause.
Thanks for any help,
91 305 tpi
heads, headers, ect.
Old Aug 14, 2003 | 11:44 AM
82355's Avatar
What condition is your battery in? I had fault code 43 on a buddies '91 B4C, and I thought it acted a lot like a bad module, so I replaced it. Well that helped a little, but then we put a new battery in it and it made it a whole lot better. It still has some issues but that is because of the hack that owned it before him. I believe the battery had a dead cell (didn't have my Fluke with me to check), so I try testing the battery, or using a known good battery.
Martin
Old Aug 17, 2003 | 09:50 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Code 42 is the ignition module, while code 43 is the knock sensor. Either one could be the problem with your car. Be sure to check the wiring to be sure its not shorted out on a header or something.
markzzzz
May 8, 2015 09:21 AM
May 1, 2015 01:14 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
