Starting problems...
Old Jul 2, 2002 | 02:04 PM
IROCKER's Avatar
Question Starting problems...
This has been going on for a while and I can't figure it out and now it's starting to really bother me. My car starts on the first try every time in the morning. And if I shut the car off after driving around and go into the store quickly and come out, it starts on the first try as well no problem. But if the car sits for a little while, and I go to start it up again, the engine still being warm, then on the first try it will just crank and crank. If I turn the key back and then try it again, it will usually work on the second try. Sometimes it takes a third shot.
The starter is new, the injectors have been checked, coil and wires are new and plugs have about 12,000KMs on them. The car runs awesome all other times, it's just the warm starts.
Any ideas?!?
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for LCA and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Vette Servo, TransGo Shift Kit, Vette 2000 Stall, TruCool LPD tranny cooler, T-tops.
Dynoed: 202HP and 292lbs-ft
1/4 Mile: 14.7s @ 92MPH
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior and engine detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Jul 3, 2002 | 07:33 AM
IROCKER's Avatar
Nobody?
1987 Camaro IROC-Z
2001 Sunfire GT
Old Jul 3, 2002 | 08:32 AM
panterachik00's Avatar
Talking
Have you checked for corrosion around the battery connections? That happend to me once with my 86 trans am, it could be that or a bunch of things,plus wiring in camaros and trans ams is notorious for going bad
Old Jul 3, 2002 | 10:16 AM
IROCKER's Avatar
Yup, the battery terminals are fine. Is there any wiring in particular that I so be looking for?
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, MSD Super Conductor wires and Blaster Coil, Energy Suspension polyurethane bushings for LCA and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, Ported Plenum, Holley AFPR, CarSound Hi-flow Cat into 3" Mandrel-bent pipes, Flowmaster muffler, Vette Servo, TransGo Shift Kit, Vette 2000 Stall, TruCool LPD tranny cooler, T-tops.
Dynoed: 207HP and 304lbs-ft
1/4 Mile: 14.7s @ 95MPH
2001 Sunfire GT
Old Jul 3, 2002 | 08:25 PM
CanIroc's Avatar
Irocker, trust me on this one. I had the exact same problem and chased it for a long time. I too had my injectors cleaned and checked and the problem still persisted. Apperently I still had one that was leaking even though they checked out OK
This is how I fixed my hard starting condition which sounds identical to yours.
NEW INJECTORS! Yup, I bought a set of Accel 23# and after I got them in it now starts just like it is brand new.
Take my word for it. By the way you know who I am too (88IROCBOB on thirdgen).
See you at St. Thomas in the fall!!
Bob
'88 IROC stock 350 TPI, auto, stock 3.27 gears, headers, Flowmaster exhaust, all the free stuff---best et 13.88 @101.18 mph
Old Jul 4, 2002 | 06:18 AM
IROCKER's Avatar
Thanks Bob...if it's new injectors than I'll be really pissed since I had everything apart over the winter. I didn't really plan on doing it all again anytime soon. I may just have to put up with it then for now. I've been worried it's the fuel pump and that's one expensive repair that I don't want to do unless absolutely necessary.
Anyway, thanks and I look forward to seeing the new mods in the fall.
1987 Camaro IROC-Z
2001 Sunfire GT
Old Jul 5, 2002 | 03:57 PM
ROCHEAD's Avatar
Wink
Fuel pump isn't that expensive. I bought the marlbaro high flow for like 150$ canadian. I did all the work myself. Mind you its not the quikest of fixes in the world, but its fun.
89 Irocz G92
L98 700R4 (All B&M and Tci 2200-2400 stall)
Minor bolt ons
Ported Plenum
ADS Super Chip
160' Thermo
All Polyurethan bushings front to back.
Lakewood LCA's and adj panhard. New fan relay heheheh. New Kuhmo 712's. (sweet tire for the price)
Old Jul 5, 2002 | 05:02 PM
Yellowknifer's Avatar
Ya fuel pumps aren't too expensive... however installing one is a GIGANTIC pain in the butt . And the labour charges WILL be high. Dropping that fuel tank is a bitch... I was looking at replacing mine with a fuel cell on another note.. anyway peace.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
