How much should nos help?
Old Jul 30, 2003 | 02:51 PM
95Z06/Z28's Avatar
Right now my car has slp y-pipe, k&n fipk, ported and gutted mass air, cat removed, flowmaster, 3.73 gears,and a madz28 programed computer on its way. I just added a NOS brand 150 dry shot kit with a walbro 255 fuel pump and i was wandering if my car would run 13.4 or 13.5 on motor, What should it run on nos if i hit it as soon as i shift to second?? Blows the tires off in 1st. Its a 95 z28 a4.
Old Jul 30, 2003 | 07:31 PM
Derrick Redd's Avatar
I'd say mid 12's. The sooner you start spraying the more ET you will drop. I hope your not running stock injectors with that 150 dry shot. I prefer the wet kits myself.
Old Jul 31, 2003 | 10:36 AM
95Z06/Z28's Avatar
Yea, i still have stock injectors. Ive only had the car 6 weeks and it was bone stock when i bought it so i'm trying to get a lot done in small period of time. I have added a walbro 255 fuel pump though.
Old Jul 31, 2003 | 05:57 PM
matt104a's Avatar
doesn't matter how big of a fuel pump you have, those stock injectors will only pump so much fuel. better run a lower shot until you can get bigger injectors
Old Jul 31, 2003 | 08:46 PM
That is exactly why I said I hope your not running stock injectors. Stock injectors tend to lock up at high fuel pressures, like with using a 150 dry shot. I'd get some 24# SVO's at least. Remember nitrous + lean fuel mixture =
Old Aug 1, 2003 | 09:32 AM
95Z06/Z28's Avatar
What size are the stock injectors? If i am going to replace them i would like to get a little bigger ones to make sure it can handle future upgrades.
Old Aug 1, 2003 | 11:22 AM
Stock is 24#. The 24# SVO's don't tend to lock up like the stock 24# do, so that might be an option. If you plan on future upgrades such as heads, cam, etc. I'd get 30#. I have the 30# SVO's. Remember you will have to change the injector constant in the PCM if you go to a higher # injector.
Mar 13, 2016 03:39 PM
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
cardemo16
Aug 24, 2015 01:04 AM
colts0455
Jul 20, 2015 09:52 AM
