How much of a change by going to 3.73's
Old Jul 31, 2003 | 11:45 AM
Don't Look Back's Avatar
Hey guys, I'm sure this has been discussed to death, but I'm wondering how much of a change I could expect by switching from 2.73's to 3.73's? Just trying to decide if I should do gears or headers...
Thanks,
Keith
Old Jul 31, 2003 | 12:26 PM
Annv Z28's Avatar
well I have the stock optional 3.23's and you can definetly notice a difference off the line with them. So I can only imagin the 3.73s will have a much bigger difference. Why not get both headers and gears...down the line you will be getting both anyway I presume
Old Jul 31, 2003 | 02:55 PM
You're correct, I am planning on both. But, I'm on a budget, so I have to do things one at a time. So after gears and headers, its RR's, then maybe a cam, an SS Hood, and Cragars...should be done around 2009.......
Old Jul 31, 2003 | 03:03 PM
TedH's Avatar
I think I would be saving for drag radials too if you want to use 3.73's. Your mph is pretty good already and the 1995's were less restrictive than the 1994 model that I have in the exhaust headers. Its pretty much a toss up in my opinion except that 3.73's will be weaker than what you have now and much more difficult to hook up at the starting line. Headers will help you gas mileage and mph. It's pretty much your choice. There is not a clear dependancy relationship going on between gears and headers.
Old Jul 31, 2003 | 03:58 PM
Alright, thanks guys...Supposing I hook up (after lots of practice) what could I expect with just the gears?
Old Aug 1, 2003 | 11:48 AM
CARGASM's Avatar
Screw the gears for now, it sounds like you can't afford to get the supportig mods right now. The supporting supension mods are what really make gears fun.
If you get the headers, especially some LT's, your car should be flying on the highway. Also, they are fun all on there own and are most likely cheaper.
Old Aug 1, 2003 | 04:56 PM
Antz97ZNJ's Avatar
huge sotp differance from the 273's probably a good 2-3 tenths
dboone2172
May 16, 2015 07:45 PM
cristian1311
May 14, 2015 07:34 AM
blac94Z
29
Mar 25, 2015 04:21 PM
