New Autotap software coming soon! (long)
Old Jun 25, 2002 | 11:25 AM
tbyrne's Avatar
Post New Autotap software coming soon! (long)
NEW AUTOTAP SOFTWARE COMING SOON!
Effective with the release of new hardware (V2.x) in early July, B&B Electronics will introduce a new version of our popular AutoTapâ Windows software. At the same time, they will be adding a “generic-data-only” version of the Windows software. This lowers the entry price of AutoTap ownership by almost $100. Additionally, they will also be introducing AutoTap for Palmä software. This easy-to-use software for the most popular handheld device can be added to an AutoTap Windows software sale, or sold separately with AutoTap hardware.
The new product line will also include a very exciting product targeted at the high-performance marketplace. They recently entered into an agreement with Starr Performance, the makers of EFILiveV5, to distribute their high performance data acquisition and control software for the LS1 engine management system. Available in a standard and pro version, the Pro version contains bi-directional controls. Utilizing AutoTap hardware and EFILiveV5 Pro software, your customers can now control IAC, idle speed, gear selection, injectors, spark advance, and much more.
All of the software products are on one CD. During installation customers will be prompted to enter a registration number that “unlocks” the software package(s) they’ve purchased. No waiting for software to be mailed and no large files to be downloaded…it’s all on the AutoTap CD.
UPDATES AND UPGRADES
AutoTap Windows software:
The new Windows software (V2.x) is considered an UPDATE for existing customers and is a free download from our website. The software will work with your customer’s existing hardware. Please refer to the attached FAQ section for differences between V1.x hardware and software and V2.x hardware and software.
AutoTap V2.x Hardware
B&B Electronics has a program in place where the customer can simply return their “old” hardware. They will replace it with “new” hardware (V2.x) for just $75.00 between now and August 31, 2002. After that, the upgrade price will be $99.95. For simplicity, these transactions will be conducted between B&B Electronics and the customer. All forms and instructions for this upgrade program will be on their website.
AutoTap for Palm software:
In order to use the Palm software, the customer will need to have our new (V2.x) hardware. They will also need to purchase a special AutoTap/Palm cable.
EFILiveV5 Software:
Starr Performance has 3 versions of its EFILiveV5 software. One version has been written to work with our “old” hardware. It does not have bi-directional controls. Two versions, standard and pro, have been written to work with our “new” hardware. The “Pro” version has bi-directional controls.
Questions and answers -
What is the difference between V1.x hardware and software and V2.x hardware and software?
There are several technical changes in the firmware that allow the V2.x hardware to update parameters as much as 30% faster than V1.x hardware. On the software side, V2.x implements many suggestions we’ve received during the last few years. There is now a default configuration screen. Additionally, the user can now view charts, gauges, graphs and meters all on the same screen. The previous version required separate screens for each view. Also, new styles and custom colors are available for graphs, gauges, charts and meters. Now the user can create and save configuration files while not being connected to the vehicle.
What equipment is required for the PC or Palm versions of AutoTap?
For Windows Operation:
IBM-compatible 486-66. Windows 95, 98, NT, ME, 2000 or XP. 16 MB RAM. CD drive (used only to load software, software may also be downloaded from the internet). 9-pin male RS-232 port.
Monitor that supports graphics recommended.
Included are a 4-foot cable to connect your vehicle to the AutoTap scanner and a 6-foot cable to connect the AutoTap scanner to your PC. You can extend the PC cable up to 50 feet.
For Palm:
Supported Palm Models: Palm IIIx, VII, M10x, M125, M50x, 70x, HandEra 330, HandEra TRGpro
Supported Palm Operating Systems: OS 3.1 and higher
AutoTap for Palm requires a special serial (9-pin) HotSync® cable (purchased separately) to connect AutoTap to your Palm This cable is different than the one used to connect to your Palm to your computer. Not all Palms use the same cable.
Included are a 4-foot cable to connect your vehicle to the AutoTap scanner and a 6-foot cable to connect the AutoTap scanner to your PC. You can extend the PC cable up to 50 feet. You MUST purchase the special HotSyncâ cable separately.
Does AutoTap for Palm include the popular data logging feature?
Yes. In order to play back a stored log file, the user must perform a HotSync with their PC. Even if the customer doesn’t buy a version of the Windows software, they will be able to replay log files on their PC.
Why do I need a new HotSyncâ cable for the AutoTap for Palm?
In its native mode, a Palm acts like a device that gets controlled by a computer. Technically speaking, a Palm is DCE (Data Communications Equipment). To work with the AutoTap scanner, a Palm needs to act like a computer, i.e. it needs to become DTE (Data Terminal Equipment). This change is accomplished by using our special cable.
Palm V isn’t one of the models you have special cables for.
Can a customer still use AutoTap for Palm with a Palm Vx?
Yes, a customer can still use AutoTap for Palm with a Palm V. They just need to purchase our part number 9PMMNM. They’ll connect this device, known as a null modem, in between the Palm V and the AutoTap. Your customer may also want to purchase a regular HotSyncâ cable from Palm or another retailer. This HotSyncâ cable will replace the HotSyncâ cradle making it easier to use the Palm V while it is connected to the AutoTap.
How much are software updates?
AutoTap software updates which include bug fixes and updated model year information are free as downloads from the B&B Electronics website. There are nominal charges for software upgrades, i.e. adding Palm software or going from the Windows generic version to the Windows enhanced version.
How long does it take to get a registration key for a customer that wants to add a software product?
Registration keys can be generated while you’re on the phone with the B&B Electronics customer service department. Remember, they will need to know your serial number and hardware version (V1.x or V2.x) in order to generate this code.
What cars can use EFILiveV5?
EFILiveV5 is for use on General Motors’ vehicles with the LS1 engine management system.
What is the difference between the versions of EFILiveV5 Software?
There are three versions of EFILiveV5 software: EFILiveV5 Standard, EFILiveV5 PRO, and EFILiveV5 V1 Standard.
All three versions are similar, with the following differences;
a. EFILiveV5 Standard and PRO utilize AutoTap V2.x hardware. The PRO version includes bi-directional controls, the Standard version does not.
b. EFILiveV5 V1 Standard utilizes AutoTap V1.x hardware. This version of the software does not include bi-directional controls.
What bi-directional controls are available with the PRO version of EFILiveV5?
Controls
Idle speed - Sets the idle speed to an rpm value in the range 0-2040 rpm.
IAC - Sets the idle air control pintle position to a step value in the range 0-127
Gear - Sets and holds the currently selected gear to one of
1. First
2. Second
3. Third
4. Drive
Injector Off - Allows the operator to perform an injector balance test by selectively turning off individual injectors. Only one injector will be turned off at any time.
Switches
M.I.L. - Illuminates the Malfunction Indicator Lamp. This feature is not available on some vehicles.
Shift skip - Illuminates the Shift Skip lamp where fitted. This feature is not available on some vehicles.
CC inhibit - Inhibits the cruise control from operating.
A/C clutch - Turns the Air Conditioner compressor clutch on or off.
Fan 1 - Turns on low speed thermo electric engine fan(s).
Fan 2 - Turns on high speed thermo electric engine fan(s).
Lift/Dive - Turns Lift/Dive compensation on or off.
A.I.R. sol - Turns the Air Injection Reaction solenoid on or off.
A.I.R. pump - Turns the Air Injection Reaction pump on or off.
Fuel pump - Turns the fuel pump on or off.
Fuel learn - Turns fuel learn mode on or off.
Closed loop - Sets fuel mode to open or closed loop.
Rev lockout - Turns reverse lockout on or off - manual gearboxes only.
TCC - Engages or disengages the Torque Converter Clutch - automatic gearboxes only.
Modes
Use spark map - Overrides the PCM's normal spark advance by substituting the values found in the currently loaded spark map.
Use fuel map - Overrides the PCM's normal air fuel ratio by substituting the values found in the currently loaded fuel map.
Evap service bay test - Puts the PCM into a mode that allows evaporative emission controls to be tested.
Fuel trim reset - Resets the learned fuel trims.
Tooth error learn mode - Puts the PCM into a mode where it can learn the crank tooth error correction
I know that this is alot of info to digest. We're still working through it too Pricing will be available on our website in the next few days.
Tom
T BYRNE MOTORSPORTS - www.tbyrnemotorsports.com
LT1 and LS1 Sales and Service
Hours 9AM-5PM EST Monday-Friday.
Order line - 1-877-4-TBYRNE
2002 Supercharged 8.1 Suburban - Project underway now!
2001 Supercharged 6.0 Suburban-15.87 @ 88.41
2000 Millennium Yellow C5 convertible- 11.92 @ 115.01
1998 Vortech powered Z-28- 10.89 @ 130.03 with 346 motor and Vortech - new ETs with 409 motor and ATI F1 supercharger coming soon!
E-mail tbyrne@tbyrne.com for lowest pricing for Vortech and ATI superchargers!
Old Jun 25, 2002 | 11:29 AM
CPFarhood's Avatar
Do you know if they will be offering any sort of upgrade to EFILiveV5 from v1.x of AutoTap?
Chris
'98 Black Z28 M6
Lid, EGR Mod, Borla Exhaust
SLP Short Throw & ****
http://cpfarhood.tripod.com
AIM: CPFarhood
*Boycot Roseville*
Old Jun 25, 2002 | 05:23 PM
Camaro ChriSS's Avatar
Tom, one would require the PRO version to control idle, gears, etc... is that right (not the standard version)? And if you have V2.xx of Autotap, this can be added?
One last question - can this be used to hold an A4 in third gear from 0-6000 rpm so as to measure a TC torque at low rpm on a dyno?
Old Jun 25, 2002 | 08:29 PM
CamaroSS_2002's Avatar
If you up the idle speed, does the computer retain the setting after autotap is disconnected? like it was tuned?
2001 Camaro SS A4 #4586
Mods: Holley Powershot Filter, WaterWetter, MSD 8.5mm Super Conductor Wires, NGK TR55's, Shaner S2 Polished TB, SLP LT Headers, SLP Loudmouth, SLP Airlid, SLP Bellows, SLP SFC's, 160-Tstat, !FRA, !TB, !MAF Screen
Coming Soon: Baer Eradispeed Cross-drilled & Sloted Rotors, Yank PY3600E, Spohn Adjustable Torque Arm
E-mail: eyedol_2000@yahoo.com
Old Jun 26, 2002 | 08:38 AM
tbyrne's Avatar
I'm sorting through a pile of info that I have for the new product and should be able to cover these questions shortly. Just want to make sure all of the answers are correct
Tom
Old Jun 26, 2002 | 04:22 PM
Thanks Tom - we'll patiently await your response.
Old Jun 26, 2002 | 09:38 PM
buschman's Avatar
Question
Hey Tom what is the difference between the new version of autotap and LS1edit?
Mike
My Navy Blue 2000 Formula Firehawk
Old Jul 2, 2002 | 05:32 PM
tbyrne's Avatar
The LS1 Edit makes permanent changes to your programming while the EFILive doesn't. The changes that you make with this software will be erased once you unplug.
We are now taking orders for the new Autotap software that will be shipping in the next few weeks. Screen shots and detailed info can be found in the ls1 f-body section of our website.
Discounted pricing for the first 30 orders that we receive is -
KAT1WG Autotap software with Windows Generic Software
$169.99
KAT1WEPT Autotap software with Windows Enhanced Software
$254.99
KAT1EFISTD AutoTap Hardware and EFILive V5 Standard
$269.99
KAT1EFIPRO AutoTap Hardware and EFILive V5 Pro
with bi-directional controls
$319.99
KAT1PG
AutoTap Hardware and AutoTap for Palm software
(Requires a special AutoTap/Palm cable)
$169.99
Tom
Old Jul 2, 2002 | 05:37 PM
ChrisFrez's Avatar
A Palm version - FINALLY
Chris Frezza / CamaroZ28.COM UBB Admin
2002 Camaro SS #1931
1995 Supercharged Camaro Z28
2001 Buick Regal GSE
Dec 1, 2016 05:37 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Ricardo
Nov 29, 2014 10:58 AM
