Will performer RPM airgap fit?
Old Jun 18, 2003 | 10:19 PM
shocker45's Avatar
I have a 1967 camaro 350. if i put on the performer rpm airgap. my holley 600. and a 14x3 filter. with the the k&n filter top. will i have enough hood clearance.
i have a weiand intake manifold right now. and about 2 1\2 inches of clearence. i got the ss hood.
Old Jun 20, 2003 | 01:45 PM
SLO SS K2's Avatar
Here is what I found. and how I found it. O have a ZZ4 350 block/383, I have an Edlebrock RPM Air_Gap, street avenger carb, and a 3" air filter.
When I saw how high the dern thing was I freaked. BUT, I put grease on all four corners (I know its round) of the chrome top and slowly closed the hood. I progressivey closed and opened it more to see if the grease was pressed or on the hood pad. I can slam my hood with no worries now but I still recommend my procedure.
Somebody might have a better idea, but I had the grease. It IS close. Don't bust a motormount
Old Jun 20, 2003 | 02:16 PM
shocker45's Avatar
i talked to my local speed shop i learnt 2 things.
The Rpm Airgap will fit the ss hood on a 67-69 camaro no problem..
and more amazingly the edelbrock rpm air gap. is the exact same height as the normal edelbrock performer rpm. its just the airgap out performs it and is a lil more money.
thankyou
Old Jun 20, 2003 | 03:04 PM
CHPshown67's Avatar
The RPM air-gap doesnt stand noticably taller than the Performer if it even does at all. the air gap is created because it dips down lower in the engine than the performer.
Old Jun 26, 2003 | 04:39 PM
gs400tx's Avatar
height of ebrock intakes
http://www.edelbrock.com/automotive/man_sbchev.html
performer -
Manifold height: A-3.50", B-4.60"
performer airgap
Manifold height: A-3.72", B-4.92" (.27" taller than #2101)
performer rpm (airgap and plain vanilla)
Manifold height: A-4.20", B-5.25" (same as #7101),
IE, performer is a minimum of ~.35" shorter than a perf rpm.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
centric
Aug 15, 2002 09:04 PM
