Just a few questions
Old Oct 12, 2001 | 08:51 PM
1994 Z's Avatar
Question Just a few questions
First of all how hard and long do you have to scrub with the clay bar to get the bug guts off? And second can i use one of my wife's 100% cotton bath towells to polish with? Also i found some bugs that i missed after i applied a coat of Z1 and Z5 how do i remove the stuff and start over, just start clay barring? Please give me some pointers this is the first time i have ever used this stuff.
1994 z28
slp headers, flowmaster cat-back, cat gutted, jet stage 2 power module, slp light flywheel and clutch assembly, ultra-z functional ram air hood, msd plug wires
Old Oct 13, 2001 | 12:07 AM
KevinSS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 1994 Z:
</font>
To remove bugs you Zainoed over, just start claying and see if they will come off, somtimes if the bugs have etched the clear coat, the clay will not be effected in removing the damage, as the clay can only remove contamination above the surface of the paint, but not below. You should use made in the USA, white color only, 100% cotton, washed only in liquid detergent, towels to remove Zaino or to use with Z-6. I recommend you have designated car towels, only used on the car. Fieldcrest Royal Velvet or Fieldcrest Charisma is the only towels Sal Zaino recommends. Here is his towel info:
Cannon & Fieldcrest make a lower quality version of their towels for K-Mart, Walmart and other big discount chains.
These towels say 100% Cotton but that is not, totally true. The nap is 100% cotton but the backing material has polyester blend in it.
So if you press a little to hard on the towel you can get some fine scratches or swirls.
The point I'm trying to make is if a Cannon or Fieldcrest towel is selling in a discount store for $6.00 or less (approximately) it is not the good stuff.
I buy all my Cannon & Fieldcrest towels in the Bath & Linen shops in the bigger stores in the mall. I pay anywhere from $10 to $20 per towel. These are the real deal. I buy about 3 or 4 towels and they usually last
me about a year.
Now for you guys that may have already purchased the lower price towels.
Look carefully at your paint finish when you are using your towels. If you are not getting any swirls or fine scratches, then you are okay. Remember it's better to be safe than swirly.
Another problem I'm seeing is some of you guys are using powdered detergent to wash your towels. Powdered detergents contain granules that do not fully dissolve in the wash cycle and get trapped in the nap of
the towels, these granules will scratch your paint finish.... Only use Liquid detergents like All or Tide. Also do not use Bleach or any kind of fabric softner.
You must use only white. Not colored towels.....Colored towels are not
to be used because the dye leaves a chemical residue on the paint finish. Always wash your towels first before using. Use Liquid detergent and rinse twice.
You should cut the selvages(borders) off the perimeter of the towels. This selvage contains nylon and polyester stitching that could possibly scratch your paint finish. The towels will fray a little once this is
done. But it's better to play it safe.
Drying the towels on high heat will make them hold a static charge. I use the regular heat setting and remove them a little damp and let them air dry. You can fluff the towel real good when it's dry to make it
softer.
As the towels get older they will lose there nap and absorbency and will have to be replaced.
Hope this ends any confusion...
96 Black Impala SS
www.zainobros.com
Remember #3
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
