Does tunercat need a language convertor ??
Old May 25, 2003 | 10:41 AM
CRCDUDE's Avatar
Question Does tunercat need a language convertor ??
I was wondering if tuner cat needs a languge convertor. I cant seem to get my PC to conect to the PCM on my 95 T-A.
My cable is from AKM.
Old May 25, 2003 | 03:15 PM
DOOM Master's Avatar
What are you trying to connect? Do you mean when you run the TC FLASH read program that it will not connect to the PCM and read the file and save it to your PC? TC tuner program itself will never interface with your PCM. All it does is allow you to view and modify the .bin files and then use the TC FLASH programmer program to upload your files. If you are wanting to view the sensor data from the PCM, you need a data logging program like Freescan or Datamaster.
MDZ28
11
Sep 24, 2015 09:15 AM
alphaauto
Jul 26, 2015 04:40 PM
whitehooptie
Jul 22, 2015 10:25 PM
jdelaprida
Jun 27, 2015 08:30 PM
1BadBrd
Aug 6, 2002 07:04 AM
