breaking rear ?s
Old May 15, 2003 | 12:44 PM
Black01_Z's Avatar
breaking rear ?s
With BF Goodrich Comp TA G-force drag radials and 3.73 gears will I be saying good bye to my rear soon or should I be fine?
EDIT: the tires are 285/30/18
Old May 16, 2003 | 02:02 AM
AL SS590 M6's Avatar
With an A4 you can run pretty hard and fast with sticky tires without a problem.
I run 3.42s, 3800stall, and ET streets. Low to mid 12s @ 108-111mph and I go to the track a LOT
Old May 17, 2003 | 03:56 PM
in2ta's Avatar
If your rear is set up good enough you can put 4.10s stage 3 heads cam nitrous and slicks without it breaking I have been running like that for a year and no problems at all
Old May 18, 2003 | 01:25 PM
96LT14u2Nv's Avatar
i agree, u should be fine with it being a A4. i might suggest welding your axle tubes as a easy protective measure
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 13, 2015 03:09 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
