Electrical Trouble PONDERING...
Old Sep 2, 2002 | 03:08 PM
Redbird's Avatar
Lightbulb Electrical Trouble PONDERING...
... If I am OVERCHARGING my battery, could this be causing my electrical troubles?
Found a burnt (I think) 15A fuse on my hot lead to the N2O relay box.
HInk
Old Sep 2, 2002 | 04:08 PM
TA Jack's Avatar
Are you using a volt blaster?
Old Sep 2, 2002 | 04:58 PM
Grover's Avatar
Unless your alternator is putting out more than 16-17 volts, I don't believe this would be causing your problem. It is possible, since all electronic items are designed for a given range of power.
The only way your going to blow that fuse is either a short circuit to ground or you have a bad relay that is pulling more that 15 amps.
Old Sep 2, 2002 | 05:06 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Question
i would have to agree with grover, check grounds. knowing you i am sure you are quite meticulous so if it isn't a ground then it just may be the relay.
g'luck!
MY car featured:
www.bmrfabrication.com.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.14@135.11mph N2O(no more excuses )
Best 60' 1.375
Best mph: 135.11mph
oh yeah also an 80 Camaro, an 98 Ram Sport, the latest addition a 94Z28, w/T-Tops!
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
Old Sep 3, 2002 | 09:43 AM
Redbird's Avatar
Unhappy
Uhhhhmmmm... dumb fluck me just figured sumpin' out... EFI N2O relay requires a 25A fuse. That would be why the 15A fuse left this world and went to fuse heaven. I seen that part in the directions but didn't understand it the way it was presented... NOW I do!!! Wondered why they included a 25A fuse??!!
Still bought a battery/alternator voltmeter and will verify B/A voltage.
By the way... I have decided NOT to run an
MSD 6A box at this time. For the LOW doses of N2O I plan to run, I don't need to take out any timing. I'll just send my old box back to MSD for a freshening (cheap azz).
HInk
Old Sep 3, 2002 | 02:08 PM
RedIrocZ-28's Avatar
Wow, glad you figured out your problem, Hink. I remember the day at Stanton you were having all sorts of problems... Good Work. See ya at M7?
Ericksd
Jan 20, 2016 06:07 PM
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
