clay spray
Old May 6, 2003 | 08:12 AM
RENE95Z's Avatar
clay spray
I bought some Clay Magic from Autozone. Clayed my car and I couldn't believe all the crap the clay pulled off the car. Anyway, I probably used half the bottle of spray and will probably finish it off while claying the wife's car. Is there a home made recipe for a spray that I can use as a substitute? I.E. A mixture of distilled water and car wash.
Old May 6, 2003 | 08:15 AM
hcvone's Avatar
Most people use a car wash/water mixture, with Zaino Car Wash one capful of Z-7 Car Wash per 16 ozs. of water, other car washes can be used as well.
Old May 6, 2003 | 08:26 AM
MikeLS's Avatar
Lightbulb
I always use a car wash solution for claying, usually Z7. The QD sprays just don't provide the lube I like to have on the finish when claying. With a car wash solution, I completely wet and soak the area in water and suds, then begin claying. I'll even soak the Zaino clay in water sometimes since it won't fall apart.
I basically use clay in the same techinque as if you were wet sanding the paint. Always keep it completely wet/soaked, and use light to medium pressure. Never had problems in doing this....
Mike
Old May 7, 2003 | 12:37 PM
fbird95's Avatar
The mothers clay bar uses Showtime as a lubricant. This stuff great for detailing and removing wax dust too.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
