Error Code: 43
Old May 5, 2003 | 06:59 PM
clasbya's Avatar
Error Code: 43
I already replaced the rotor, the cap was still in good shape. Do I need to replace the distributor itself? I am still using my old wires, though I dont think this would cause an error that relates to the distributor.
Old May 5, 2003 | 07:45 PM
krazzycowgirl's Avatar
Code 43 is Knock Sensor (KS) or Electronic Spark Control (ESC) circuit fault
Old May 6, 2003 | 06:42 AM
clasbya's Avatar
I was reading in my Haynes and Chitlins(Chiltons) books and they describe the ESC as being part of the distributor. My dad told me he had a big issue with the ignition module on his fiero so I think I will start there. Autozone has a way of testing this module to see if its a problem child or not. I didnt think of the error code meaning a problem with the knock sensor, I will have to take a look into that one.
Old May 6, 2003 | 07:16 AM
irocz8957's Avatar
yeah i had the same problem i had to replace my knock sensor!
Old May 6, 2003 | 09:52 AM
clasbya's Avatar
sweet, thanks yo.
Old May 6, 2003 | 11:18 AM
aklim's Avatar
KS error code could be Bad KS, Bad connection to ECM, Bad wire to ECM or Bad ECM
Old May 7, 2003 | 06:48 AM
Error's Avatar
Hey, we had this one:
We ended up replacing the whole ignition system since it was tripping a few other codes. New cap/rotor/HEI module/& coil and we're back in business.
The 305 is still slow though
Old May 7, 2003 | 09:05 AM
clasbya's Avatar
I sure I dont have to go that far.
Though I would like to replace my POS 3.1l v6 for a nice v8. Prolly go for a used 350 and have it rebuilt.
Nayr
Mar 3, 2023 08:34 PM
marlar98
Sep 19, 2015 07:53 AM
RobFlag
Aug 29, 2015 11:40 PM
whitehooptie
Aug 10, 2015 07:02 AM
asilomar244
Jul 12, 2015 05:53 AM
