1/2 inch play in Dshaft after moser 12 bolt install, to little?
Old Jul 18, 2002 | 06:00 AM
wytblur's Avatar
Post 1/2 inch play in Dshaft after moser 12 bolt install, to little?
I just put my new rear end in, and the stock driveshaft only has about 1/2 in play in it now, is that to little, or will i be ok?
Old Jul 18, 2002 | 06:34 AM
rje's Avatar
rje
That should be fine. Moser may have just set yours up a little closer that's it.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
Old Jul 18, 2002 | 07:32 AM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
Exclamation
3/4 to 1 inch is the standard.
I don't know if I'd like only having a 1/2".
Old Jul 18, 2002 | 05:10 PM
TedH's Avatar
I snipped off 1/2 inch off the driveshaft when I installed the Moser. When fully loaded 1/2 inch doesn't seem like enough.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Jul 19, 2002 | 08:48 AM
When I went through the trauma of a broken ACPT CF DS (they accused me of bottoming it out - it didn't) I spent some time researching. Consensus seemed to be that 1/2" clear is fine for a stock setup, 1" clear was required for a healthy power adder.
My Mark Williams is set up that way (as was my ACPT, but that's a long story).
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 19, 2002 | 09:49 AM
jp2002ls1's Avatar
If you have over 350 horsepower I would definately correct it and get atleast 3/4" play so that you don't ruin your driveshaft. Do you have adjustable LCA's and panhard? I don't exactly know how the Moser is set up but I am sure you can get an extra 1/4" to have a safe amount of play.
Old Jul 19, 2002 | 10:26 PM
OneFlyn95z28's Avatar
Lightbulb
My Moser left me with 1/4 play. Un accepable. I bottomed it out the first time I stalled it hard. I will be ordering a New Denny's Nitrious shaft a 1/2 inch shorter
THAT is my exceptable limit after year of racing
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
ddr698
Jan 9, 2015 10:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
sleeperZ96BT
Sep 5, 2002 05:45 PM
Brad 97z
Aug 10, 2002 09:58 AM
