Getting the Ultra Z hood and not having the SS style airbox for it???
Old Apr 18, 2003 | 06:57 PM
KamaroL98's Avatar
I just ordered the Ultra Z hood and wont have an airbox for it, its designed to work like the SS/Ws6 ramair hood but i will have to go w/o the air box for awhile, will it mess anything up if water gets inside the motor? And also, im going to convert it to actual ram air sooner or later and SLP dosent list an air box for that hood anymore, does anyone know where i could get something else other then an SS box overpriced from a dealer??
http://www.slponline.com/img/part_img/100000Z.jpg
Old Apr 18, 2003 | 07:17 PM
V6toZ28's Avatar
Uhhh ... I believe the SS airbox and the Z28 airbox are the same.
Now the Ws6 airbox is little higher than the Camaro airbox and will fit fine under the UltraZ hood.
As far as where to get one cheap, try a wrecking yard.
Good Luck
Old Apr 18, 2003 | 07:21 PM
KamaroL98's Avatar
Hows that? Something has to be different.....
Old Apr 18, 2003 | 07:25 PM
Alucard's Avatar
nope, on LS1 SS's the air is routed around in the hood itself (hence the reason its not terribly effective) It looks like double C's the air comes in at the top, swings around, then goes into the same airbox as a Z
Old Apr 18, 2003 | 07:26 PM
bigsteve7's Avatar
The difference for the "ram air" system is all in the hood.
In the last year or two you could order a SS with a aftermarket SLP lid though. Not every car has one.
Old Apr 18, 2003 | 07:35 PM
KamaroL98's Avatar
Okayyyy, looks like ill have me a ramair Z28 with two sources of air going into the intake. Does the SS have the same set up where it gets air fromt he grille area as well?
Old Apr 18, 2003 | 09:13 PM
V6toZ28's Avatar
The SS get very little air from the grill ... though the air flow is still there. The hood intake comes up pretty snug to the air box ...
Old Apr 18, 2003 | 09:17 PM
Nathan1234's Avatar
And you would be 100% correct.
If you plan on using the hood intake and not a free ram-air sort of thing, try a WS6 air box. Really though, the ultra Z/SS/WS6 hoods are pretty much for looks (especially SS) and you'll probably gain more from cutting out the bottom of the air box and removing the shroud.
Old Apr 18, 2003 | 09:18 PM
6speedZ28's Avatar
Re: Getting the Ultra Z hood and not having the SS style airbox for it???
Ummmmmmmmmmmmm, yup....then you would say hello to a load of problems!!!
Old Apr 19, 2003 | 12:47 AM
KamaroL98's Avatar
Re: Re: Getting the Ultra Z hood and not having the SS style airbox for it???
I mean 'on' the motor, not inside it. But it looks like i wont have that problem since it will be ram air...
Old Apr 19, 2003 | 02:08 AM
chpmnsws6's Avatar
mine is open on my ws-6 and i was in a HEAVY blinding rainfall and all it did was idle at like 1700rpm till the rain stopped and it sat there for a few minutes.
anyone know what happened to it right then and there to idle high?
thanks,
mike
Old Apr 19, 2003 | 02:17 AM
AmmoZ's Avatar
the ultra hood uses the stock air box the outlet on the hood comes out in front of the opening of the airbox. There's a divider inside the opening that blocks the rain. All I've done was raised the airbox about 1/2 inch with washers and put a seal around the edges on the underneath side. hope this helps ya, That hood is sweet........
Old Apr 19, 2003 | 11:13 AM
#7's Avatar
KamaroL98 sounds like this hood will work great with the KN KIPK.
Nice looking Z hood,I might get one...let us know what condition you recieve it in prep wise.And the fitment.
Old Apr 20, 2003 | 04:12 AM
KamaroL98's Avatar
OK, soon as i get it back ill let everyone know...
KYWes
Jun 14, 2022 06:52 AM
Henson071
Dec 30, 2015 09:55 PM
karpetcm
Aug 14, 2015 03:02 PM
dolfan324
Jul 17, 2015 10:34 PM
CARiD
Jul 7, 2015 08:19 AM
