TH350 conversion, how did you get the speedo to work?
Old Apr 4, 2003 | 11:41 AM
jamesge's Avatar
I have a 95Z28.
Old Apr 4, 2003 | 12:07 PM
kazman's Avatar
I haven't worked that out yet. My speed reads way high. It is unpluged for now. I hope LT1 edit will correct the reading. I installed the ring reducer and stuff listed in other postings but I still have the problem. Maybe my 4.11 gears has something to do with it.
Old Apr 7, 2003 | 08:24 AM
Shon Herron's Avatar
If you have an OBDII car you can hook up to the ABS stuff. if you have an OBDI car then it is a bit more difficult....I had to get a set up from Dakota Digital for less than $110 and it works. i have to fine tune it but i know how fast I am going within a couple of MPH.
email me or post here and I can give you more info as needed. ie part numbers from Dakota Digital and how i set mine up.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Dec 1, 2016 05:37 PM
blac94Z
Feb 10, 2015 11:02 AM
Queens94z28
Dec 20, 2014 09:11 PM
