97 PCM in a 95
Old Apr 1, 2003 | 12:03 PM
MZK4252's Avatar
97 PCM in a 95
I am tracking down some bad misfires and I have heard that they may be the fault of the PCM.
If I switch my extra PCM from a '97 Z28 into my '95 TA what can I expect? They are both M6 cars. I just want to check to see if this eliminates the misfire-if it does then I know it is the PCM. This is by no means permanent, as I am aware of the OBD stuff, but I just want to check out my PCM.
Any thoughts?
Old Apr 1, 2003 | 07:51 PM
94ZRagtop's Avatar
I'm honestly not sure how well it will run, but it is doable. I put a '96 PCM in my '94Z, but I disabled the crank position sensor code, the rear O2's, and I tweaked the wiring harness a tad so that I could get OBDII data on my OBDI diagnostic connector.
The thing you might lose is reading the knock sensor - I seem to recall not getting any knock retard readings at all. The KS for a 94-95 is a different impedance than the KS for a 96-97.
I switched because the OBDII PCM doesn't freak out with a high stall torque converter.
-Andrew
Old Apr 3, 2003 | 11:42 AM
MZK4252's Avatar
In case anyone was wondering, I will close this question up. I tried hooking up the '97 PCM in my '95. Of course the SES light went on, but nothing funny other than that. I have 30# injectors, so it ran rich, but that was also to be expected. I still had my misfire, so I'm guessing that it's not the computer. Back to the drawing board...
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
