LE2 Stock bottom end lt1 426rwhp 393rwtq through ford 9"
Old Nov 22, 2009 | 01:42 PM
  #16
c5formula's Avatar
Originally Posted by 96azhawk
Is this a M6 car? Is so, the 60' is not too bad.
yes its a stock 145k 97 T-56, short block has 145k on it also.
Old Nov 22, 2009 | 02:29 PM
  #17
brad3579's Avatar
Very nice.
Are you using LE - 230/234 .592/.592 111 LSA or 236/240 .592/.592 112 LSA?
Thanks
Brad
Old Nov 22, 2009 | 03:24 PM
  #18
c5formula's Avatar
Originally Posted by brad3579
Very nice.
Thanks
Brad
i cant really say but i will say that my cam is smaller than both of those cams you just listed. also my cam is a nitrous cam that im not runnin nitrous on so it could be better im sure but it does make power and carry it all the way past 6700rpms...
Old Nov 22, 2009 | 03:26 PM
  #19
c5formula's Avatar
here is a video of it on the dyno making the 426rwhp and 393rwtq. shows the dyno graphs at the end of the video.
Old Nov 22, 2009 | 07:49 PM
  #20
reamo04's Avatar
get a two step in it and launch it higher. You ahve the rear end to hold it, and your tires should hold no problem.
Id be doing a 2 step and launching about 5k
Old Nov 22, 2009 | 08:43 PM
  #21
c5formula's Avatar
you have any idea as to what 2 step i should go with? which one will work with my setup? im running the delteq coil on plug setup...
Old Nov 22, 2009 | 09:19 PM
  #22
reamo04's Avatar
I have a MSD digital 7 with a 2 step in my car. Im a bit biased towards that. However its also around a grand.
Old Nov 22, 2009 | 09:32 PM
  #23
c5formula's Avatar
holy crap thats alot of money lol.
Old Nov 22, 2009 | 10:01 PM
  #24
SS MPSTR's Avatar
Sixty-footing a M6 car well is difficult. While 1.76 isn't great, it isn't bad either. More seat time will certainly help get those numbers down.
Old Nov 23, 2009 | 02:45 AM
  #25
c5formula's Avatar
oh for sure just need to get out there more. just sucks cause our track down here is probably one of the worst prepped tracks around and its always packed.
Old Nov 23, 2009 | 09:10 AM
  #26
jasonisdn's Avatar
my .02 cents. get that thing tuned for real. after tuning on mine for a month (only a few hours on the weekends, mind you) i cant see a mail order tune being even close to right. it might give you a starting point but nothing more. did you atleast have the wideband hooked up on the dyno run and if so what were the readings thoughout the run? the real problem i see is in the ve tables at part throttle and closed throttle position. if that isnt right the car will wash the rings and bearings out or run too lean and produce tons of extra heat and risk buring a piston. good job so far just make sure you keep at it and finish it.
Old Nov 23, 2009 | 07:25 PM
  #27
c5formula's Avatar
i dont really have the know how nor the ability to tune the car myself, wish i did though and the closest tuner to me that can tune lt1 cars is thunder racing and they want like $600 to do it. i dont really have to money on hand to pay for something like that....
Old Nov 23, 2009 | 10:06 PM
  #28
69z-28's Avatar
while a mail order tune isnt your best option, it is obviously doing well for you. assuming your car is running well (seems like it is based on those track and dyno numbers), then hold off on the dyno tune until you get tired of the way the car runs now and have a little play money. you will most likely see a gain from a vehicle specific dyno tune, maybe 5 rwhp, maybe 30 rwhp who's to say. either way that's a strong MFer. spend the money on visiting your track and learning that sucker great numbers regardless. perfect example of an old LT1 still performing awesomely on somewhat of a budget.
Old Nov 24, 2009 | 12:04 AM
  #29
c5formula's Avatar
yeah i will have a dyno tune sometime soon just dont have the cash now. and this whole thing was deff on a budget, think i might have around 4k in parts spread over about 5 years or so...
Old Nov 24, 2009 | 02:28 AM
  #30
maddog05's Avatar
You have done it right ~ what a strong car and the LT1 is just breaking in
Congratulations on a smart modded car. I am jealous!
