Mallory 685, will the staging control override the window switch?
Old 01-03-2009, 03:56 AM
speedracer2j's Avatar
Ive searched with no definite answers, but
Has anyone tested to see if while using the mallory 2 step function, does this disable the window switch?
speedracer2j is offline
Old 01-04-2009, 09:39 AM
jakesz28's Avatar
I did not actually test that and wondered about it myself but I just used a relay to make sure that the window switch did not cause the nitrous to spray until I released the transbrake(which activated the two step).
jakesz28 is offline
Old 01-06-2009, 10:25 AM
Ray@NitroDaves's Avatar
you will need to use a relay to cut power to the kit when you are on the 2 step.
here is a diagram showing the wiring for a trans brake...the 2 step would wire the same way
Ray@NitroDaves is offline
Speeds8erM-1
08-20-2002 09:12 PM
Speeds8erM-1
08-15-2002 10:07 PM
Speeds8erM-1
08-13-2002 10:24 PM
Speeds8erM-1
07-28-2002 06:18 PM
Speeds8erM-1
07-18-2002 11:36 PM
Quick Reply: Mallory 685, will the staging control override the window switch?
