Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
M12 is less than a couple of months away already!
Old 08-26-2007, 10:12 PM
  #31
ws6transam's Avatar
I hope that you are there too, Taner.
I wanna pick yer brain on how to launch a 6-speed.
ws6transam is offline
Old 08-26-2007, 10:19 PM
  #32
IrocSS85's Avatar
floor throttle, dump clutch. hold on. hahaha.
taner, just curious, I respect what your doin with the quickest t56 and all, but just curious at what point is all that tranny work/money taking away from your drag racing experience/fun factor? I know to me, I would have been like- hell with that long ago.
but I too hope you'll be there so I can watch your car make some sick pass's
IrocSS85 is offline
Old 08-27-2007, 06:38 PM
  #33
taner's Avatar
Location: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
dan,
see above
to me it is all about driving it on the street! i don't believe i could have a car that traps low 9's and drive it on the street and highway when i choose. then again with as much as it has been broken lately it takes away from that. only one more goal and i will dial it back!!! well a wee bit anyhow!
1.5 passes after putting it back together it is broken again!!!! and on motor! wtf!!!
taner is offline
Old 08-27-2007, 07:34 PM
  #34
IrocSS85's Avatar
well I know what your saying with the overdrive, but a gear vender could make a th400 low 9sec car pretty happy on the street. however the proper stall conv. to run what you got might not like street driving. that would probably be a consession (spelling?) to make. but I hear ya. I do love a good T56. just not in the car I want to go to the track with.
IrocSS85 is offline
Old 08-27-2007, 10:01 PM
  #35
taner's Avatar
well since i can't afford another car like that with an auto then there is no point. the T56 is one huge compromise for track use/ optimal ET. i drop my trans off tomorrow
taner is offline
Old 08-27-2007, 10:19 PM
  #36
IrocSS85's Avatar
still working with the guys at D&D?
IrocSS85 is offline
Old 08-28-2007, 07:36 AM
  #37
Moderator
AL SS590 M6's Avatar
But think about this a properly set up nitrous converter for a shot like Tanner runs would be very tight on motor so with the TH400/Gear Vender combo it would drive very nicely on the street, on motor.
AL SS590 M6 is offline
Old 08-28-2007, 08:08 AM
  #38
ws6transam's Avatar
After M12 is over, I'll probably be pulling my T56 out for an R&R. Taner, I expect to be hunting you down at the event because I have some questions for you about how to tackle this SFI 6.1, 6.2, 6.3 specification in an LT1 configured T56 application. From what I can tell, it looks like I might have to chuck the whole LT1 clutch assembly to make it work. I'd sure hate to have to lose my aluminum flywheel because I love it's revvability! Your insight would be most helpful----
Old 08-28-2007, 10:41 AM
  #39
IrocSS85's Avatar
good point
IrocSS85 is offline
Old 08-28-2007, 03:39 PM
  #40
AutoRoc's Avatar
My new 3000 stall is more streetable than my explorer. She is a DOOOOG on motor now folks!
3000rpm+3.73+Powerglide+28"=+Bottle=
AutoRoc is offline
Old 08-28-2007, 07:13 PM
  #41
IrocSS85's Avatar
powerglide? you sillie frank. what happened to the th400 idea? just teasing but I am curious why you went with the 2 speed instead?
IrocSS85 is offline
Old 08-29-2007, 07:54 PM
  #42
AutoRoc's Avatar
Never planned on a 400, just chose between the 2. Plenty of people having good results in heavy cars at a decent power level with a 2 speed. After seeing Scott's similar combo go low 9's on 2 occasions sealed the deal. 1 occasion he used first gear. Another, he accidentally left in second gear(th400)...Timeslip really didn't show a difference. Saves a few pounds, supposedly is more efficient, and I think it will be more consistant. Less shifting on the street too, no downshift for a highway race.
AutoRoc is offline
Old 08-29-2007, 09:09 PM
  #43
IrocSS85's Avatar
what about the 60? his 60 was near the same? I know for some applications, having the higher 1 gear of the glide will get more traction and a quicker 60 due to less torque trying to turn the tire. you talking about scott K's camaro? or a different scott?
so you bringing the camaro to M12 or what? what kind of times you plannin on running with it?
IrocSS85 is offline
Old 08-30-2007, 05:44 PM
  #44
AutoRoc's Avatar
I don't remember specifics but if the ET was similar I'd assume the 60 was also. It was consistant low 9's back then. M12 is for sure and we'll see what it runs tomorrow at Milan. 10.60's with the crap converter flashing to 6000 out of the hole. This new one should see 4000 on spray and maybe take advantage of the whole powerband, not just 6000-7000. No reason it shouldn't go 9.9X with hook and the same 150 jet. MPH should go from 122 to 135-137'ish. I'm not certain but it sounds right to me.
AutoRoc is offline
Old 08-30-2007, 05:58 PM
  #45
IrocSS85's Avatar
cool. I agree, should see 9's IF the new convertor does what tis supposed to. it'll be a wild ride thats for sure. plus, if you hit 150mph, you got a built in parashute. just pull the lever(s) hahaha.
dont you have to be certified to run 9.XX?
IrocSS85 is offline
Quick Reply: M12 is less than a couple of months away already!
