Which walbro 255, high pressure or low pressure?
Re: Which walbro 255, high pressure or low pressure?
I have the high press. pump and no AFPR. it works great.
1racerdude, I'll ask for him. where do you get a walbro 305 and how much do they cost? I got my pump from new era cause its cheaper then anywhere else I found it.
chris
chris
LOL, I asked that exact same question about 3 weks ago....I was told, go with hi pressure if you think you might ever go with a power adder. For NA, lo press is fine. Are you ordering the wire harness kit too? I havent decided if I'm going with pump only or pump & wire kit. I hear a lot of guys say they have voltage drop over the old harness, but I'm pretty good with wiring & may just re-terminate the existing harness
http://www.autoperformanceengineering.com/
I got my walbro from them, it was only 97 bucks
Get the racetronix's kit. Plug and play.
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Got the kit with the wiring kit from Thunder Racing. The BEST intank plug and play set-up you can buy.
10-31-2016 11:09 AM
Skull Leader
08-10-2002 11:01 AM
snksknr94
08-02-2002 07:31 PM
