turns over very slow
Hi my name is Jeff and I'm new to the site. I got a 94 z28 and I am trying to get it running. Started off with a new battery, but when I try to crank it, it turns over very, very slow. Almost like the battery is going dead, but its not. So I hooked up a jumper box put it on 200 amp start and it still turns over very slowly. I then took the starter off and took it to the local auto store to have it tested, and it tested good. Hooked starter back up, but let me make sure I have it hooked up right. (only two wires going to the solenoid, one is purple going to the S terminal and the other is the big wire that is the hot wire going to the big terminal on the solenoid. I also have a small black and white wire where does this hook up? When I took the starter off it was not hooked up to anything) Is this a ground wire of some sort. The car has been setting for about a year, I have checked and fuel pump is kicking on, I also replaced the coil and am now getting spark, but still engine turns over way to slow to crank the car. Any and all help is appreciated. Jeff
Re: turns over very slow
I am curious as to what else this could be. I Just put a new battery into my Camaro last month and I still have the same problem.
I have been suspecting that it's my starter. Even if it tested good there could be something wrong causing it to turn slowly.
My starter used to spin like a top, and crank right over. Now it's err...err...err..errrr VROOM. It's like the battery is low, but as I said, it is brand new.
Not sure how the starter hooks up, but if you test it and it is good then maybe something in the engine is cauing the drag that slows the starter. Did it START up perfect last time you ran it?
hey thanks guys for the replys, they are helpful. I will let yall know what I find.It will be a week or so though{the car is at my ol mans house 180 miles from me}The pics where really great,thanks again. also love the site Jeff
formula79
26
08-05-2002 12:21 PM
