Melling oil pump question
Old 10-12-2011, 08:34 AM
Dtimekw's Avatar
I have two oil pumps, HV and SV/SP (10550 and 10554). I cant find the same pickup that is currently on my HV (small tube). Since the new pump (SV/SP) is a 3/4 tube, my question is this, can I switch oil pump body covers? The two appear to be the same. This way I can still run my aftermarket small tube on the SV/SP pump. Also, I would like to up the pressure a bit, what spring do you recommend? My mains are ~.0025 and rods are ~.0029. Thanks guys.
Dtimekw is offline
Old 10-12-2011, 02:26 PM
Dtimekw's Avatar
Re: Melling oil pump question
I talked to Melling and was told the M55's have the same cover and are interchangable. Just be sure and check which spring is in them and make sure you switch those too.
Dtimekw is offline
Old 10-12-2011, 02:42 PM
GM white spring or Melling pink are the same 70# spring.
shoebox is offline
Old 10-12-2011, 04:07 PM
Dtimekw's Avatar
Thanks Shoebox!
Dtimekw is offline
HectorM52
07-30-2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Queens94z28
12-20-2014 09:11 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: Melling oil pump question
