Stock lt1 cam specs
Stock lt1 cam specs
Does any one know the specs on a stock cam?
Is This like stock specs
http://www.compcams.com/Company/CC/c...csid=1101&sb=2
Re: Stock lt1 cam specs
Some good LT1 info in this article:
http://www.enginebuildermag.com/Arti...t1_engine.aspx
Includes this table:
inspecting will be a pain considering im still in the middle east since uncle sam loves to take forever to send a man home from deployment
is there a code on the options list for my car to tell exactly which lt1 model i have in my 95z??? or would i have to go inspecting on my motor to find out for sure?
I'm not sure what your question is. You have a 95, and they give you one spec for a 95 F-Body. You have the exact same engine that is in every other 95 F-Body. There are no optional "models".
Comp's rpm ranges are complete bull. The stock b-body cam which is listed in the above chart is MUCH smaller than the f-body cam duration wise. Yet with good valvesprings and 1.6 rockers is routinely turned to 5800.
Why don't you just tell us what you are trying to accomplish and we can help you get there?
If trying to put together a basically stock engine I would use a stock cam before a cheap cast Comp. I am sure a LOT of guys would let one go for shipping cost.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
Brandon Wittmer
12-03-2014 09:28 PM
