Pics of a 95 F Bod Fuse/Relay Box??
Could anyone take pics or list the order that all of their fuses and relays are in? I found a link to the 95 dealer manual but according to it all of my fuses are out of order. If that is the case then when someone broke into my car and stole my relays (and fuse box cover) they also pulled some of my fuses out and rearranged them.
I am refering to the engine bay located fuse/relay box with the plastic cover on it.
I purchased all of the relays and fuse/relay cover out of a 96 and its diagram that is on the inside of the fuse/relay cover is also in a dif. order than that of my fuses.
The relays I can probally figure out as I only have 3 different ones and if I can just find out where the ABS one goes then there is only 1 other different one.
No sorry I mean the engine bay fuse/relay box. The box with the huge plastic bolt in the middle of it. On right side of engine bay.
HAHA, the pic is so HUGE I didnt even see the pic of what I need on the right side. Thanks, Brad
Listen to Shoebox.... the Owner's Manual has diagram of both the inst. panel fuse box and the under hood relay/fuse box. It also has a list of what is on each fuse. There are subtle differences from year to year.
Use the link to the factory Owner's Manual on Shobox's website. Couldn't be easier.
I know the owners manual has one. I have one and the download of it from shoebox's site. Its just that it didnt make sense to me that someone would purposfully pull my fuses out and swap them out with others. Makes no sense, but it happened
carguyshu
01-22-2017 11:19 AM
Latronaxe
05-14-2015 01:23 PM
Latronaxe
04-29-2015 08:25 AM
